Volume increments of a surface
Hey guys, Newbie here getting frustrated with Civil 3D.
Here is the scoop. I have a complete surface created. I need to know the volume of that service at certian elevations. If it where one or two, I would either use a bonded volume or create another surface at the desired elevation. I need it at 80 different elevations on two different surfaces (160 total for now). Is there a simple way to get the volume at 0.1m increments??? I really don't want to spend the next 2 days creating surfaces and/or bonded areas....
Any help would be great, thanks...
coulee....:bc:
Anyone??? I found several ways to do it manually. I just find it hard to believe that Civil 3D doesn't have a way to do it when every other program I have used will.
No idea. Ask the question at theswamp.org.
Thanks rustysilo...will check it out... :bc:
