nickjhall Posted April 29, 2010 Share Posted April 29, 2010 Hi, I have a series of drawings generated in a design package that prefixes an L to the layers is generates. It generates layers in sequential numbers, with layers starting from L100 then L101 etc... I also have a .dws file set up to change layers from the design package standard to my companies CAD standards using the LAYTRANS command. Problem is the .dws was set up without the L prefix on the original layers. There's quite a lot of different layers so dont want to rename manually, is there a way of automatically removing the L prefix from all layers in a drawings? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted April 29, 2010 Share Posted April 29, 2010 Try the Rename command Old Name > L* Rename to > * 1 Quote Link to comment Share on other sites More sharing options...
nickjhall Posted April 29, 2010 Author Share Posted April 29, 2010 ah-ha! perfect, thanks Quote Link to comment Share on other sites More sharing options...
