I'm confused as to why it didn't work. What happened?
For what information you provided, I was able to make it work on my end.
I indulged you, now do me the same courtesy.
  • Replies 37
  • alanjt
    12
  • SteveBubendorf
    7
  • Piper
    5
  • Lee Mac
    4
I'm sure it is something that I'm doing or setting incorrectly, (or didn't explain well enough in my first post). I used El. 115'-6" and EL. 114'-6 1/2". I added 10, which I thought was 10 feet, and got the following, repectively: EL. 126'-6" and EL. 125'-6".
I hate to be taking up your time, Alan, since this was just a learning excercise for me. I appreciate the help, though !!!!
Nah, it's fun (when I have the time to play).
Post me a file with a few elevations. I will admit, it doesn't take into account the inches not being whole numbers (wasn't thinking about that).
I'm in the middle of a few things, but I might play around with it tonight.
Alan,
I attached a drawing with a few elevation text entities. I also attached the previous Lisp file that I had to accomplish the task that we are communicating about. It seems to work for me as long as the text is formatted correctly and units are set properly, etc. I was just looking for another way to "skin the cat", I guess, as a learning experience.
Thanks, again, for the help !
Elevations.dwg
ELCI.lsp
Steve,
Maybe a good place to learn about (distof) function:
(distof "115'-6")
1386.0
Maybe that would make the math a bit easier. -David
Steve,
(distof "115'-6")
1386.0
Oh yeah, I wasn't thinking about units. I'm dumb.
Dumb ! Yeah, right ! I wish I were only a fraction as "dumb" as you with this stuff, then ! Knowing that distof is the key, I'm still having trouble adjusting your code, perhaps cause I'm so "smart", then ???? Still workin' at it, though. Thanks, Alan ! Thanks, David!
I've got to take a break from this, so if you guys do any more posting, I won't see it until later. (Been up for over 30 hours with insomnia. 'Gotta give sleep another shot.) I'll look at anything you post later, and respond accordingly. Thanks, again !!!
Not quite! I forget ( distof ) 5 times fro every time I remember it.....
-David
hi,
I am arriving in late, but this i will give you below should fix your problem. it is also usable for those who don't have vl function ( like me ) so it's look like more complicated than what have been proposed before but it's also more generic so you could adapt it by youself to make it run for your need. Basicaly it use the distof function to manage the architectural units. You can specify a string before and a string after to match for parsing your texts entities. For the example I ve been testing like this
>:add_value_in_text
>Type the layer name: ISOMOD
>Type a specific value for selecting text or key ENTER for all: 10'
>Type a text to match at begining of the value in the text: EL +
>Type a text to match at the end of the value in the text:
>Type the value to add: 845'
then all the EL +10' in my drawing has become EL +855'-0"
here is the source code freely licensed at just one restriction don't use ckado, capcpo or my real name for any commercial purpose. I just test it for your example it may have bug for other case.
the lsp file:
(defun addx2str ( x str str_match_begin str_match_end /
;; author: CAPCPO
;; 05.11.2010
stmp
i
ib ;begin
ie ;end
n
m
notfound
value
;;;; first find the value for addition and its position ;;;;;;;;;;;;;;;
;;;; if a str_match_begin specified ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(if
(eq str_match_begin "")
;;;;;;;;;;; if no str_match_begin ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(setq
i 1
ib i
;;;;;;;;;;; if str_match_begin ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(setq
i 1
n (strlen str)
notfound T
m (strlen str_match_begin)
(while
(and
notfound
(setq
stmp (substr str i m)
notfound (not (eq stmp str_match_begin))
i (1+ i)
(if
(null notfound)
(setq
i (+ i m)
ib (1- i)
(if
(null notfound)
(if
(eq str_match_end "")
;;;;;;;;;;;; if no str_match_end ;;;;;;;;;;;;;;;;
(setq
ie (1+ n)
;;;;;;;;;;;; if str_match_end ;;;;;;;;;;;;;;;;
(setq
notfound T
m (strlen str_match_end)
(while
(and
notfound
(setq
notfound (not (eq stmp str_match_end))
i (1+ i)
(if
(null notfound)
(setq
ie (1- i)
;;;;;;;;;;;; if the str has been parsed then process the new string and send it back ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(if
(null notfound)
(setq
m (- ie ib)
stmp (substr str ib m) ; the sub text containig value for addition
value (distof stmp) ; convert architectural units to a real
str (if
(numberp value)
(strcat
(substr str 1 (1- ib))
(rtos (+ value x) 4 4) ;convert the new value to architectural
(substr str ie)
;;;;;;;;;;; if nothing were found then return nil ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
);fin
(defun c:add_value_in_text ( /
;; author: CAPCPO
;; 05.11.2010
n
i
ss
lent
assoc_str
str
x
s_value
s_match_begin
s_match_end
assoc_newlayer
s_x
(setq assoc_newlayer (cons 8 (getstring "\nType the layer name: ")))
(setq s_value (getstring 'cr "\nType a specific value for selecting text or key ENTER for all: "))
(setq s_match_begin (getstring 'cr "\nType a text to match at begining of the value in the text: "))
(setq s_match_end (getstring 'cr "\nType a text to match at the end of the value in the text: "))
(setq s_x (getstring 'cr "\nType the value to add: "))
(setq x (distof s_x))
(while
(not (numberp x))
(princ "\nerror: not able to read the value, try again")
(setq
ss (ssget "_X" (list (cons 0 "TEXT") (cons 1 (strcat s_match_begin s_value s_match_end "*"))))
i 0
(if
ss
(repeat (sslength ss)
(setq
lent (entget (ssname ss i))
assoc_str (assoc 1 lent)
assoc_layer (assoc 8 lent)
str (addx2str x (cdr assoc_str) s_match_begin s_match_end)
lent (if
str
(entmod (subst assoc_newlayer assoc_layer (subst (cons 1 str) assoc_str lent)))
(princ "\nError: impossible to get value in text")
(print (cdr assoc_str))
(print lent)
(prin1)
(exit) ;exit or just warning up to you
i (1+ i)
(princ (strcat "\nno text found with the value " s_match_begin s_value s_match_end "*"))
(prin1)
);fin
I thanks you for the advices.
I will enclose the next lisp with code tag in the futur. As you read my thread you may have noticed that I have given CAPCPO as name of author and perhaps it makes you feel suspicious about my rights to publish this code. It just because i don't want to give my personnal name. Not because I don't want that people know who i am but because i don't want that my name be indexed by crawl bot. It just a question of privacy. I agree with you that this is problematic for copyrights. CAPCPO is the name of my website where I published some lisp. May be should I write capcpo.com instead of capcpo but that sounds too much like an advertissement...
One solution could be to insert a picture containing my name but i don't know if cadtutor will allow me to do that and if it is possible?
ckado
I understand your concerns, but really, what's in a name?
1) Who's to say the name you display actually is your name anyway?
2) Out of 6 billion people, I wonder how many will have exactly the same name as you
3) What is anyone going to do with just a name anyway?
Just saying :)
dear alanjt,
you 're right: what is a name? But have you ever try to launch search engines with your personal name? What would you think if all your private life is readable by 6 billion people?
ckado
dear alanjt Lee Mac,
Well, I suppose that depends on how much of your private life you upload to the net...
In th early days of peer to peer moderated forums ( compuserve ) it was common practice and considered more professional to use your real name. I don't think that I've had any more or any less spam / phishing / pranks than most of the people that I know who use monikers. Hell, I even use my real name as a domain. There are still a few guys that hang out at the Autodesk forums that go back that far as well. So I wouldn't be but so worried about using the name given to you by your parents. My $0.02. -David
a name and particulary my name is realy not a big deal but indexing names is already a problem, just think about it.
while few of us will upgrade themselves others will upload themselves
nice to talk with you
  • 7 years later...
Hi All
Can you help me to get a lisp file for adding increment in the Chainage in the format of CH. 0+100.000 Km. Also please help if we can Place in the array
