gamulj Posted April 26, 2010 Posted April 26, 2010 Hi! I have made corridor with cut grade and now I'am interested what is the best way to hide or cut terrain over cutting slopes? Quote
Hardney Posted May 17, 2010 Posted May 17, 2010 Not sure if I understand corrctly, but here is my what would be the answer to what I understand: if you want to hide the contours that are being cut by the corridor, you can go in Corridors>Utilities>Create Polyline from corridor and then select your daylight to create polylines from them. Now you might have to explode them and put the lines at 0 to the start and end in Z. Then you join all your daylight lines and create a wipeout that you set above your surface. That would be one solution. Or else you could insert you corridors top surface into you existing terrain. Hope this helps. Quote
