Can someone write me a lisp that would use the quick select command to find all the red circles in my selection (size does not matter) and change the color from red to green
Thanks Mike
Did you try QSelect?
[ATTACH]19234[/ATTACH]
common. yes, that is what i have been using all along. I was hoping a lisp command would make things go a little faster. Plus I can modify the lisp command to use it for things other than just red circles.
Ahh, OK.
This will only select select red circles (ignoring locked layers):
(ssget "_:L" '((0 . "CIRCLE")(62 . 1)))
Can you code the change or do you need help?
Ahh, OK.
Can you just provide me with a breakdown of how you got to the code you have now. (Im still trying to learn)
Thanks Mike
I tried it and it does not give me a error, it just does nothing
"(defun c:rtg ()
is ^ correct?
actually I just realized that is only half the code, how to get it change to green.
Dig through this site.
This will also help:
;;; VLA & DXF Info of selected Primary or Nested object
;;; Alan J. Thompson
(defun c:Info (/ #Choice #Obj)
 (vl-load-com)
 (initget 0 "Nested Primary")
 (and (or (setq #Choice (getkword "\nNested or Primary object [Nested/<Primary>]: "))
          (setq #Choice "Primary")
      ) ;_ or
      (cond
        ((eq #Choice "Primary")
         (setq #Obj (entsel "\nSelect Primary object for VLA & DXF info: "))
        ((eq #Choice "Nested")
         (setq #Obj (nentsel "\nSelect Nested object for VLA & DXF info: "))
      ) ;_ cond
      (not (textscr))
      (princ "\nVLA Info:\n\n")
      (vlax-dump-object (vlax-ename->vla-object (car #Obj)) T)
      (princ "\nDXF Info:\n")
      (mapcar 'print (entget (car #Obj)))
 ) ;_ and
) ;_ defun
Here is what I have come up with, I know im close. but far from it at the same time.
(defun c:rtg ()
  (command "change" "p" "color" "red")
You are very close, just think about how Change works.
eg.
Select objects:
Specify change point or [Properties]: p
Enter property to change
[Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/Material/Annotative]: color
New color [Truecolor/COlorbook] <BYLAYER>: green
Define your selection to a variable also. Don't mess with Previous nonsense.
(setq ss (ssget "_:L" '((0 . "CIRCLE")(62 . 1))))
(command "_.change" ss "" "_P"...
(defun c:rtg ()
  (command "_.change" ss "" "P" "color" "green")
so that is what I have now, but its stopping at the "p" part and asking me to click "color". when I click "color", "3 (green)" is already entered, I just have to press enter twice to exit the command. how can I just make it go through without any prompts??
Another way:
(defun c:Colr ( / i ss e )
 (if (setq i -1 ss (ssget "_:L" '((0 . "CIRCLE") (62 . 1))))
   (while (setq e (ssname ss (setq i (1+ i))))
     (Update (PutDXF 62 3 (entget e)))))
 (princ))
(defun PutDXF ( code value elist )
 (entmod (subst (cons code value) (assoc code elist) elist)))
(defun Update ( elist )
 (entupd (cdr (assoc -1 elist))))
Another way:
 (if (setq i -1 ss (ssget "_X" '((0 . "CIRCLE") (62 . 1))))
 (princ))
one problem, you have no way of selecting. I cant do the entire drawing, only what i select
(defun c:rtg ()
So close! You forgot the ending "". Also I added an if statement to ensure a selection was made before issuing the change command and localized your ss variable.
(defun c:rtg (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "CIRCLE") (62 . 1))))
   (command "_.change" ss "" "_P" "color" "green" "")
Another way:
LoL
While correct, you're putting the cart before the horse. Don't you think? Let him get comfortable with making selections and simple changes first.:wink:
Lee, ... You're Awesome !! :thumbsup:
It's funny, ... when guru's such as yourself are posting code, it is automatically assume the reader knows what the code is - simply because you use it so often, you don't give it a second thought. I find myself posting without an explanation all to often, but that's because I know you guys understand it much better than myself.
I find the explanation listed after the line of code help tremendously.
And your help Lee is ALWAYS welcome !!
(defun c:rtg (/ ss)
LoL
Doesn't seem to be foolproof here. If the circle is on a layer whose color is red, it doesn't change it to green. However, typing change etc., the same circle can be made green. WTH?o:)
Because there's a big difference between a circle that's red (object level) and a circle that's on a layer that's red. The ssget filter only selects red (object level) circles to change to green.
Isn't that desired result?
Understood !!!
As someone recently said, "Learn something new every day !"
Thx Alan
Understood !!!
Thx Alan
Happy CAD'ing.
Thanks Hangman - I don't always get a chance to provide the explanation after each line, but glad it helps. :)
(defun c:rtg (/ ss)
LoL
works great thanks.
now how can I change this so that it only selects objects under layer "3D_HWR" and explodes them?
(defun c:hex (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "layer") ("3D_HWR"))))
   (command "explode" "")
^^^^Am I close or way off?^^^^
