Need some help on this "Afralisp-routine" (to modify it...)
Click this link to see the whole routine:
http://www.afralisp.net/archive/vl/acadset.htm
THis part is where my question is:
;;;Set up the AfraLisp Support Paths
;set the path to the AfraLisp subdirectory.
(setq netpath "C:\\AfraLisp2002")
;set the support paths to the AutoCAD default
(setenv "ACAD" "")
;store the default paths
(setq defpath (getenv "ACAD"))
;set up the AfraLisp paths
(setenv "ACAD" (strcat
defpath ";"
netpath ";"
netpath "\\" "Menu;"
netpath "\\" "CadLisp2k;"
netpath "\\" "CadLib2k;"
netpath "\\" "CadMech;"
netpath "\\" "Hatching;"
netpath "\\" "Help;"
netpath "\\" "Profiles;"
;set up the custom template path
(setenv "TemplatePath" (strcat netpath "\\" "Templates"))
;inform the user
(prompt "\nAfraLisp Support Paths Defined\n")
How would I modify the code so my current search paths remain asthey are, so the new paths are to be added? I am in the middle of something but whenever I execute the routine, it copies the profile like it should but the SFSP's are overwritten with the new ones?
Sorry if I am not totally clear... my goal is to keep the SFSP and ADD the new ones, not loose the old ones.
Any help is appreciated, as allways.
BTW: all credits to AfraLisp of course!!
Here's one I compiled for work...
(defun c:CES-Setup (/ #Files #Layout #Flag)
 (vl-load-com)
 (and
   (not
     (vl-catch-all-error-p
       (vl-catch-all-apply
         '(lambda ()
            (setq #Files  (vla-get-files
                            (vla-get-preferences (vlax-get-acad-object))
                          ) ;_ vla-get-files
                  #Layout (vla-get-activelayout
                            (vla-get-activedocument (vlax-get-acad-object))
                          ) ;_ vla-get-activelayout
            ) ;_ setq
            ;; **  AutoSave Path  **
            (mapcar 'vl-mkdir (list "c:\\TEMP" "c:\\TEMP\\ACAD"))
            (vla-put-autosavepath #Files "c:\\TEMP\\ACAD")
            ;; **  Printer Config Path  **
            (vla-put-PrinterConfigPath
              #Files
              "s:\\cadd standards\\Plotters"
            ) ;_ vla-put-PrinterConfigPath
            (vla-refreshplotdeviceinfo #Layout)
            ;; **  Plotstyles Path  **
            (vla-put-printerstylesheetpath
              #Files
              "s:\\cadd standards\\Plotstyles"
            ) ;_ vla-put-printerstylesheetpath
            ;; **  Template Path  **
            (vla-put-TemplateDwgPath
              #Files
              "s:\\cadd standards\\Template"
            ) ;_ vla-put-TemplateDwgPath
            ;; **  QNew Template  **
            (vla-put-QNewTemplateFile
              #Files
              "s:\\cadd standards\\Template\\CES_Template.dwt"
            ) ;_ vla-put-QNewTemplateFile
            ;; **  Support Paths  **
            (vla-put-supportpath
              #Files
              (strcat ";s:\\cadd standards\\startup"
                      ";s:\\cadd standards\\lisp"
                      ";s:\\cadd standards\\linetypes"
                      ";s:\\cadd standards\\fonts"
                      ";s:\\cadd standards\\ces layers"
                      (vla-get-supportpath #Files)
              ) ;_ strcat
            ) ;_ vla-put-supportpath
            ;; **  Tool Palettes Paths  **
            (vla-put-ToolPalettePath
              #Files
              (strcat "S:\\CADD Standards\\Toolpalette\\Palettes;"
                      (vla-get-ToolPalettePath #Files)
              ) ;_ strcat
            ) ;_ vla-put-ToolPalettePath
          ) ;_ lambda
       ) ;_ vl-catch-all-apply
     ) ;_ vl-catch-all-error-p
   ) ;_ not
   (alert
     (strcat
       "AutoCAD has been setup for Capital Engineering & Surveying, Inc. Standards.\n\n"
       "                      Please restart AutoCAD."
     ) ;_ strcat
   ) ;_ alert
 ) ;_ and
) ;_ defun
(alert "Type: \"CES-SETUP\" to run setup.")
Thanks guys!!
Now let me do some homework tonight!!
 (vl-load-com)
 (and
   (not
       (vl-catch-all-apply
         '(lambda ()
                          ) ;_ vla-get-files
            ) ;_ setq
              #Files
              #Files
              #Files
              #Files
              #Files
              ) ;_ strcat
              #Files
              ) ;_ strcat
          ) ;_ lambda
   ) ;_ not
   (alert
     (strcat
     ) ;_ strcat
   ) ;_ alert
 ) ;_ and
) ;_ defun
Alan,
Maybe I cannot read it well enough but what is the difference between yours and mine? I mean, does yours add the paths?
  MarcoW said:
Alan,
Yes, it adds the paths. I took the Visual Lisp route as shown in Larry's link. Also, in addition to Support Paths, mine sets many others (eg. ToolPalette, Plotter Config., QNew Template, Template, etc.). Just look at the comment sections.
Okay, that I could not see.
Since you (and maybe many others) have walked that way, I believe it might be a good way!
I did read it Alan, and read the comments. Allready played with it, not succesfull but that will work out.
I have a routine alike yours, but I do not need so many things to set. (I use toolpalettes and SFSP..) My problem is to add... like I said.
Thank you very much for the response, I can go on for a while now :)
It won't work if the paths do not exist.
Even if it's more than you need, it gives you options on adding several others.
Happy CAD'ing. :)
  alanjt said:
It work work if the paths do not exist.
You mean it only works if the path exist, am I right?
How come that this does not work:
              #Files
       (strcat "[size=4][color=blue][b];[/b][/color][/size]C:\\MarcoW"
                      "[b][size=4][color=#0000ff];[/color][/size][/b]"
              ) ;_ strcat
... while the map "C:\MarcoW" does exist :oops:
Another question, and maybe it has got something to do with it:
What's up with the ";" in the code (what I made blue above).
What does that thing do in the code? I ask because in my code it seems to be on the end of the line...
Thanks for helping me out.
              #Files
              ) ;_ strcat
What you posted works fine on my end. Actually, it added it without having the path created.
As far as the semicolon goes, it's just to break to the next path (multiple paths). I just put it in the beginning because it just seemed a little cleaner/neater to put it first.
It's just like using "\n" in a string.
eg.
(strcat "\nALAN" "\nThompson") = (strcat "\nALAN\n" "Thompson")
Alanjt,
The code indeed works, it adds a support file search path! Thanks for the input, I might have shuffeld a bit around with those ";" thingies.:oops:
There is not some code to prevent double paths, if you get what I mean. I tried it twice and I got the path "C:\temp" twice in the options dialog.
Now let me try to figure it out allthough I have no clue how to start :D, as allways, I am a full time beginner, haha.
Okay, but to start I stripped down the code so all I need is left (imagine me getting confused in such big routine LOL)
 (vl-load-com)
 (and
   (not
       (vl-catch-all-apply
         '(lambda ()
                          ) ;_ vla-get-files
            ) ;_ setq
            [color=navy][b](mapcar 'vl-mkdir (list "c:\\TEMP" "c:\\TEMP\\ACAD"))[/b][/color]
              #Files
              (strcat ";c:\\temp"
              ) ;_ strcat
          ) ;_ lambda
   ) ;_ not
   (alert
     (strcat
     ) ;_ strcat
   ) ;_ alert
 ) ;_ and
) ;_ defun
(The blue part I now recognize, you know...)
Somehow I would need toch check if one the current support file search folders matches one of the new ones. If they match than skip that one....
No really, I have no clue. Can you help me?
  MarcoW said:
Alanjt,
 (vl-load-com)
 (and
   (not
       (vl-catch-all-apply
         '(lambda ()
                          ) ;_ vla-get-files
            ) ;_ setq
              #Files
              (strcat ";c:\\temp"
              ) ;_ strcat
          ) ;_ lambda
   ) ;_ not
   (alert
     (strcat
     ) ;_ strcat
   ) ;_ alert
 ) ;_ and
) ;_ defun
Yeah, I never bothered with checking for duplicates (no point) since it only gets run once on new installs.
I would suggest using wcmatch to see if a string already exists in existing Support Paths. If it returns true, do nothing, if nil, add to Support Paths.
I know you said you recognize the blue portion, but just to clarify, it was just to create the "c:\\temp\\acad" directory on the c:\ drive.
BTW, you might want to remove all my company specific prompts/labels. LoL
Yes I know, but I just know it for a short while :wink:
o:) I thought you liked that, ... no, I have forgotten....
You say "if a string allready exists"... So with wcmatch I should be able to see if the string "c:\temp" is allready in the paths.
But then the question how to do it. I mean, first I'd need to get all the supportfile paths in a list am I right?
eg.
(setq ExistingPaths ";c:\\folder1;c:\\folder2;c:\\folder3")
(setq NewPaths (list "c:\\folder3" "c:\\folder4" "c:\\folder5"))
(setq string "")
(foreach x NewPaths
 (or (wcmatch ExistingPaths (strcat "*" x "*"))
     (setq string (strcat string ";" x))))
(vla-put-supportpath ...
