Natalsharks Posted August 26, 2008 Posted August 26, 2008 Hi all, I don't know if there is anyone out there that might already have done this I have looked through the site and there are some lisps that are similar but don't do exactly what i want them to do. I even tried playing around with them in vlisp but I have only just started trying to learn how to write lisp routines. Anyway cut a long story short I need a lisp routine that changes all mtext and text in a drawing to font style ISO and font type ISOCP.shx with a height of 200 with all justifications to remain as is. If anyone has something out there that would be most appreciated. Cheers Quote
Strix Posted August 26, 2008 Posted August 26, 2008 which was the nearest and what didn't it really do for you? (just in case it's a good base for somebody to write you something more specific) Quote
borgunit Posted August 26, 2008 Posted August 26, 2008 Check here, they have quite a bit of great snippets... http://www.4d-technologies.com/techcenter/ Quote
lpseifert Posted August 26, 2008 Posted August 26, 2008 First, if you're using LT, you won't be able to use lisp unless you have an add on such as Lt-extender. Also, you should be able to do what you describe using the Properties palette. Create a font style named ISO using the font ISOCP.shx. Select all the text/mtext (look into using Quick Select), change the style and height in Properties. Quote
Natalsharks Posted August 27, 2008 Author Posted August 27, 2008 Thanks for all the replies. lpseifert you reminded me to update my profile i am running the ful version of autocad 2008 . I found stripmtext.lsp on the net which does what i want yay!! thanks for the replies. Quote
