alanjt Posted April 22, 2010 Posted April 22, 2010 stevesfr said: Lee, above lisp works fine here.1-call up original block with attributes in new drawing 2- use Bedit to add one or more additional attributes 3- close Bedit window 4-enter attsync 5- Wblock revised block to overwrite original block 6- call up dwg with blocks to be updated 7- load and run ReDef 8-clap hands together !!!!!!! Steve It DID redefine the existing block? I could have sworn vla-insertblock wouldn't redefine. Learn something new every day. Quote
dbroada Posted April 23, 2010 Posted April 23, 2010 sorry, I've been to bed while all this has been going on. As Lee has said, you only need to redefine your block once and WBLOCK it to somewhere in your search path. Then you can insert that in to each drawing in turn. My script for doing this is something like..... -insert oldBlockName= y 0,0 1 1 1 0 erase l qsave as Alan has said, the = calls to insert an external copy of the block, not the one already in the drawing. The "y" is to accept the redefinition of the block. If you are doing this from the command line you can escape at this stage but I haven't found an easy way to send the escape character so I insert one copy of the block then erase it. If you are using an older version of AutoCAD you may need to zoom extents here. On old versions ERASE LAST would only erase the last visible object. Quote
Herewegoagain Posted April 23, 2010 Author Posted April 23, 2010 Hi guys, Thanks for all your responses; it looks like what I want to do is certainly achievable but, because I know nothing of programming within CAD, and have only just heard about lisps and scripts, I am unsure how to apply the fixes you’re offering, any further explanations you could offer would be greatly appreciated. Thanks yet again Andy Quote
dbroada Posted April 23, 2010 Posted April 23, 2010 the first thing to note is that you don't need to go to block edit on each drawing. Do it once and WBLOCK your new file somewhere. Then either insert that using the dialogue box and browse for the file or use the command line -INSERT and use the = method. That will save you some time in each drawing! I still wouldn't want to do that 350 times though. A script is a text file that is read one line at a time and acts like you are typing the commands. I haven't got script pro or Lee's efforts so can't comment on what you need to do to construct ascript but just copy what I have put above into notepad and save it as "test.scr" (obviuosly use your block name). Open one of the drawings you want to change and either drag the script onto the drawing window or type SCRIPT and navigate to test.scr & ok. Then report back. Quote
alanjt Posted April 23, 2010 Posted April 23, 2010 If you have non-LT AutoCAD, you can send LISP commands through a script file. eg. (command "_.-insert" "c:\\ALAN.dwg=" nil) (command "_.attsync" "_N" "ALAN") If loaded as an .scr, it could modify all desired drawings. Quote
alanjt Posted April 23, 2010 Posted April 23, 2010 dbroada said: Alan, does that nil exit the command? Yes. That way you only insert the definition into the drawing (redefining if exists). No objects are created. Quote
dbroada Posted April 23, 2010 Posted April 23, 2010 I'll try to remember that then - save me erasing last. Quote
alanjt Posted April 23, 2010 Posted April 23, 2010 dbroada said: I'll try to remember that then - save me erasing last. Definitely a little safer. Quote
Herewegoagain Posted April 24, 2010 Author Posted April 24, 2010 thanks for all your help everyone, I have been doing some reading, and think I'll be ready to have a play on Monday when I get into work, i'll let you know how I get on!! Thanks again everyone!! Quote
