  • Replies 34
  • Lee Mac
    15
  • alanjt
    6
  • gordon_Gjs
    4
  • woohhoo
    3
Posted Images
Habit I suppose - wanting to be certain, but I suppose it is a bit redundant.
Thanks mate. :)
Lee Mac that works greats and is what I am looking for! Would it be possible to make an adjustment if I am not being too picky? Could the value be centered in the middle of the line instead of floating on top?
Do you know if this could be reworked to work in Autocad 2010 LT with an add-on tool-kit?
I tried to run it using the "SlingShot" tool-kit and it comes up...
"Select objects:
; error: unable to get ObjectID: "
...After I select the object and hit enter.
Thanks for this great Lisp! Great Job!
I'm not sure about the LT Extender, as I have never worked with one, but I can certainly center the Text in the middle of the Polylines/Lines.
Would you like a Background mask also?
Could it be possible to make one with and without mask so I can compair? Sorry if I am a bug! Thanks!
Try this Gordon,
I've added Circles and Arcs also:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:PlL [b][color=RED]([/color][/b] [b][color=BLUE]/[/color][/b] *error* spc i ss e Der p obj typ [b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [i][color=#990099];; Lee Mac  ~  29.04.10[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] *error* [b][color=RED]([/color][/b] msg [b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]wcmatch[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] msg[b][color=RED])[/color][/b] [b][color=#a52a2a]"*BREAK,*CANCEL*,*EXIT*"[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#a52a2a]"\n** Error: "[/color][/b] msg [b][color=#a52a2a]" **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] spc
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [color=Blue][b]AcModelSpace[/b][/color]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveSpace[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=Blue]:vlax-true[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-MSpace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ModelSpace[/color][/b] doc[b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-get-PaperSpace[/color][/b] doc[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=#009900]-1[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#a52a2a]"CIRCLE,ARC,LINE,*POLYLINE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] e [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Der
       [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009999]0.[/color][/b] [b][color=#009999]0.[/color][/b] [b][color=#009999]0.[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getFirstDeriv[/color][/b] e
           [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] e
             [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] p [b][color=RED]([/color][/b]MidPoint e[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj
       [b][color=RED]([/color][/b]MCMText spc p [b][color=#009999]0.[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#a52a2a]"%<\\AcObjProp Object(%<\\_ObjId "[/color][/b]
           [b][color=RED]([/color][/b]GetObjectID [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] e[b][color=RED])[/color][/b] doc[b][color=RED])[/color][/b] [b][color=#a52a2a]">%)."[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#a52a2a]"CIRCLE"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] typ [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] e[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
               [b][color=#a52a2a]"Circumference"[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#a52a2a]"ARC"[/color][/b] typ[b][color=RED])[/color][/b]
               [b][color=#a52a2a]"ArcLength"[/color][/b]
               [b][color=#a52a2a]"Length"[/color][/b]
           [b][color=#a52a2a]" \\f \"[/color][color=#a52a2a]%lu6\[/color][/b][b][color=#a52a2a]">%"[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-put-rotation[/color][/b] Obj [b][color=RED]([/color][/b]MakeReadable Der[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] MCMText [b][color=RED]([/color][/b]block point width string [b][color=BLUE]/[/color][/b] o[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vla-put-AttachmentPoint[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] o [b][color=RED]([/color][/b][b][color=BLUE]vla-AddMText[/color][/b] block
             [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b] point[b][color=RED])[/color][/b] width string[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=Blue]acAttachmentPointMiddleCenter[/color][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vla-put-InsertionPoint[/color][/b] o [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b] point[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] MakeReadable [b][color=RED]([/color][/b] a [b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>[/color][/b] a [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] [b][color=BLUE]pi[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] a [b][color=BLUE]pi[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] a [b][color=BLUE]pi[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>[/color][/b] a [b][color=BLUE]pi[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<=[/color][/b] a [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009900]3[/color][/b] [b][color=BLUE]pi[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] a [b][color=BLUE]pi[/color][/b][b][color=RED])[/color][/b]
     a
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetObjectID [b][color=RED]([/color][/b] obj doc [b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#a52a2a]"X64"[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]getenv[/color][/b] [b][color=#a52a2a]"PROCESSOR_ARCHITECTURE"[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]vlax-invoke-method[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Utility[/color][/b] doc[b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b]GetObjectIdString obj [b][color=Blue]:vlax-false[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]itoa[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Objectid[/color][/b] obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] MidPoint [b][color=RED]([/color][/b] e [b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getPointatDist[/color][/b] e
     [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getDistatParam[/color][/b] e
       [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getEndParam[/color][/b] e[b][color=RED])[/color][/b]
     [b][color=#009999]2.[/color][/b]
Thanks mate. :)
No problem. Hope the link helped.
I just tried it and it works great, how hard would it be to take off background mask?? Thanks!
  • 3 years later...
Hats off to both Lee and Alan ... lifesavers the both of you. Posted a similar question today requesting similar output ... should have known that you guys would have already encountered it and dealt with it by now.
Thanks again.
  • 8 months later...
Hi. Prompt how to change lisp removing autonumbering, but leaving the alignment?
  • 1 year later...
Hi Lee,
You may be able to assist me with this:
Making DIMARC.lsp execute globally (or should I say, execute in a loop). Hence labels all arc segments in a drawing.
Please note that preference is arc, not 3 Point Angular Dimension.
Attached lsp files could lead you through.
Sincerely with thanks,
Edwin
DIMARC.lsp
MDIM_Multiple Polylines.lsp
By the way, it is likewise requesting a lisp to convert 3 Point Angular Dimension to Arc globally.
Cheers,
Edwin:)
