I have autocad lt 2204
I'm having trouble inserting a jpeg to a drawing in paper space. Any ideas?
Steve
I used 'insert raster image' from the 'insert' menu and had no problem at all
You could also try opening the image in MS Paint, copying and pasting it into the layout.
LT doesn't have the IMAGE command; "insert object--ole" or copy/paste is the only way to go.
In the future I can see needing to insert jpegs, photos, and othe scanned objects......does having the LT version limited me from doing this?
F700 or is it 007f
nothing in life is free....thanks for the site
No not much is free in life. 007?? yeah..I like that ;)
  • 6 years later...
I copy past a logo in a drawing but when converted in dXf , sent , when open the jpg wasn't there enny more... What shoud i do?LOGO.jpg
This is because the DXF format is an ASCII file, so cannot contains an image. Use DWG format instead, or if DXF is mandatory try to attach the image and ship it along. Other solution will be to trace over that logo.
By the way, did you noticed that this a thread from 2005?
thanks.
Even if its 2005 you still answered! i'm new at this site. i did think the initial date of post mattered... i thought if something new was posted it would show.
I sent an e-transmit and the logo was included ..did work.
Ii took the jpg copy past it in the drawing then modify it inside the drawing.
so i should modify it with Photoshop then attach as an xref is that it?
Edited by mezuluyu
