hrehor Posted April 16, 2010 Posted April 16, 2010 Hi all, I came across a problem with finding duplicates of blocks that have different attributes. Overkill doesn't find them, nor any of LISPs I found on the web - duprem, dupdel, deldup. A simple LISP that would highlight/select blocks that have same insertion point would do the thing. Anyone has a LISP like that? Greg Quote
leigh_elkins Posted April 16, 2010 Posted April 16, 2010 Can you not just use quick select and then filter the properties? Quote
hrehor Posted April 16, 2010 Author Posted April 16, 2010 I don't quite get it. I select 77 of my blocks and in properties I have *varies* in X and Y. How can I know which of 77 blocks have the same insertion points (all of them should be different)? Quote
leigh_elkins Posted April 16, 2010 Posted April 16, 2010 So the blocks all have the same name but with a different insertion point? Sorry but I am not sure I completely understand your situation. Quote
dbroada Posted April 16, 2010 Posted April 16, 2010 I'm reading the problem as..... He has 77 blocks of one type in his drawing. SOME of these blocks are placed on top of each other. He wants to be able to remove the duplicate blocks to end up with just one block for each insertion point. but I could be reading the question incorreclty. Quote
hrehor Posted April 16, 2010 Author Posted April 16, 2010 I'm reading the problem as..... He has 77 blocks of one type in his drawing. SOME of these blocks are placed on top of each other. He wants to be able to remove the duplicate blocks to end up with just one block for each insertion point. but I could be reading the question incorreclty. Exactly. Once the problem is finally described, anybody has a solution? Quote
Lee Mac Posted April 16, 2010 Posted April 16, 2010 (edited) This may be a touch overkill, but I wanted to write something interesting (defun c:BlockDupes (/ GroupByFoo i ss e eLst) (vl-load-com) ;; Lee Mac ~ 16.04.10 (defun GroupByFoo ( foo lst / f g ) (defun f ( x l ) (if l (cons (vl-remove-if-not (function (lambda (a) (foo x a))) l) (g (vl-remove-if (function (lambda (a) (foo x a))) l))))) (defun g ( l ) (if l (f (car l) l))) (g lst)) (if (setq i -1 ss (ssget "_X" '((0 . "INSERT")))) (progn (while (setq e (ssname ss (setq i (1+ i)))) (setq eLst (cons (cons e (cdr (assoc 10 (entget e)))) eLst))) (mapcar (function (lambda ( group ) (if (> 2 (vl-list-length group)) (mapcar (function (lambda ( entity ) (ssdel entity ss) ) ) (mapcar (function car) group ) ) ) ) ) (GroupByFoo (lambda (a b) (equal (cdr a) (cdr b) 1e-4) ) eLst ) ) (sssetfirst nil ss) ) ) (princ) ) Edited February 2, 2024 by Lee Mac Quote
dbroada Posted April 16, 2010 Posted April 16, 2010 having decided that you have a number of blocks on top of each other, how do you know which one had the correct attribute? Quote
hrehor Posted April 16, 2010 Author Posted April 16, 2010 having decided that you have a number of blocks on top of each other, how do you know which one had the correct attribute? That could have been a problem,but in my case blocks are room tags, where the only difference is area attribute. After cleaning I will get the right att. or empty - it is visually easy to distinguish. I need to delete duplicates to avoid problems in data extraction. DX could be other way to find duplicates by comparing blocks positions, but very ineffective. Greg Quote
hrehor Posted April 16, 2010 Author Posted April 16, 2010 This may be a touch overkill, but I wanted to write something interesting thank you Lee Mac. YOU ROCK :-) did you just write it? Greg Quote
Lee Mac Posted April 16, 2010 Posted April 16, 2010 thank you Lee Mac. YOU ROCK :-) Thanks Greg did you just write it? Yes Quote
Least Posted August 3, 2017 Posted August 3, 2017 Hi Lee An old post but a useful routine. I was wondering how to modify your blockdupes routine so that one of the duplicate blocks is left unselected in each instance, then I can run a command to delete previous or to move the duplicate blocks to a new layer. It doesn't matter which duplicate block is left. I have attached an example drawing, how can I go about modifying the selection to achieve this? I would be thankful for any help with this as I don't know where to start. It would be like an overkill for duplicate blocks. Many thanks block dupes.dwg Quote
Lee Mac Posted August 3, 2017 Posted August 3, 2017 Consider the following: (defun c:blockdupes ( / ent idx ins lst rtn sel ) (if (setq sel (ssget "_X" '((0 . "INSERT")))) (progn (setq rtn (ssadd)) (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) ins (cdr (assoc 10 (entget ent))) ) (if (vl-some '(lambda ( x ) (equal ins x 1e-4)) lst) (ssadd ent rtn) (setq lst (cons ins lst)) ) ) (sssetfirst nil rtn) ) ) (princ) ) Note that the code considers blocks to be duplicate based solely on insertion point coordinates which are within 1e-4 (0.0001) units of each other, independent of block name. 1 Quote
Least Posted August 4, 2017 Posted August 4, 2017 Thanks Lee it works perfectly I have added (66 . 1) to select only attributed blocks to the selection set criteria and it does exactly what I was after. Thank you very much! Quote
Pugazh Posted November 17, 2019 Posted November 17, 2019 (edited) On 04/08/2017 at 02:06, Lee Mac said: Consider the following: (defun c:blockdupes ( / ent idx ins lst rtn sel ) (if (setq sel (ssget "_X" '((0 . "INSERT")))) (progn (setq rtn (ssadd)) (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) ins (cdr (assoc 10 (entget ent))) ) (if (vl-some '(lambda ( x ) (equal ins x 1e-4)) lst) (ssadd ent rtn) (setq lst (cons ins lst)) ) ) (sssetfirst nil rtn) ) ) (princ) ) Note that the code considers blocks to be duplicate based solely on insertion point coordinates which are within 1e-4 (0.0001) units of each other, independent of block name. Hi lee, how to select this two block Original Block (entget (car (entsel))) ((-1 . <Entity name: 7fffe0ed940>) (0 . "INSERT") (330 . <Entity name: 7fffefcb9b0>) (5 . "5B636C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "RANGELAYB1") (6 . "Continuous") (48 . 10.0) (100 . "AcDbBlockReference") (2 . "*U2120") (10 1.01773e+006 148993.0 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0)) Duplicate Block (entget (car (entsel))) ((-1 . <Entity name: 7fffdd7e300>) (0 . "INSERT") (330 . <Entity name: 7fffefcb9b0>) (5 . "62E218") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "RANGELAYB1") (6 . "Continuous") (48 . 10.0) (100 . "AcDbBlockReference") (2 . "*U3336") (10 1.01858e+006 149389.0 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0)) Edited November 17, 2019 by Pugazh Quote
BIGAL Posted November 17, 2019 Posted November 17, 2019 The assoc 5 is the handle of the block this is a unique id if you want two try (5 . "62E218,5B636C") 1 Quote
JayR Posted February 2, 2024 Posted February 2, 2024 On 4/16/2010 at 2:16 PM, Lee Mac said: This may be a touch overkill, but I wanted to write something interesting [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:BlockDupes [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] GroupByFoo i ss e eLst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [i][color=#990099];; Lee Mac ~ 16.04.10[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GroupByFoo [b][color=RED]([/color][/b] foo lst [b][color=BLUE]/[/color][/b] f g [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] f [b][color=RED]([/color][/b] x l [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] l [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if-not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]foo x a[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] l[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]g [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]foo x a[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] l[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] g [b][color=RED]([/color][/b] l [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] l [b][color=RED]([/color][/b]f [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] l[b][color=RED])[/color][/b] l[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]g lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=#009900]-1[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#a52a2a]"_X"[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#a52a2a]"INSERT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] e [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] eLst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] e [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] e[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] eLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b] group [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-list-length[/color][/b] group[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b] entity [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssdel[/color][/b] entity ss[b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=Blue]car[/color][color=RED])[/color][/b] group [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b]GroupByFoo [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]a b[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]equal[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] b[b][color=RED])[/color][/b] [b][color=Teal]1e-4[/color][color=RED])[/color][/b] [b][color=RED])[/color][/b] eLst [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sssetfirst[/color][/b] [b][color=BLUE]nil[/color][/b] ss[b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b] [b][color=RED])[/color][/b] Could you please provide the plain text version of this code? I'm unable to view it otherwise. Thank you. Quote
Lee Mac Posted February 2, 2024 Posted February 2, 2024 I've updated my earlier post to remove the BBCode formatting - however, I should note that the code is very old! Quote
JayR Posted February 7, 2024 Posted February 7, 2024 On 2/2/2024 at 5:57 PM, Lee Mac said: I've updated my earlier post to remove the BBCode formatting - however, I should note that the code is very old! Hi Lee, Thank you for updating. I appreciate it. Quote
