can a spline be join to a line,pline or an arc..I use pedit command but it doesn't work , only the line and arcs were join. can anyone has an idea ?:geek:
No, you cannot join a Line and a Spline.
I generally don't use Splines. I usually draw out a Polyline for my curved path and then switch to PEDIT and choose the "Spline" option to get the curvature. There is also a "Decurve" option that will return the Splined Pline to it's original state. Doing this allows me to add segments later if I need to.
The only other suggestion I would make is that if the final objective is to create a planar, closed loop then the Region command will allow the joining of splines, lines, polylines, arcs, and elliptical arcs.
