When compile even simpliest code like the sample below with "Separate Namespace" option and always appears:
"no function definition: LAYOUTLIST"
If compile it with document namespace (Separate Namespace - unmarked) then code running ok.
Any idea where is (and how to solve ) the problem?
(defun C:PPP( / aa)
 (setq aa (layoutlist))
 (print aa)
add
(vl-arx-import 'layoutlist)
or (to avoid other problems with initdia, startapp...)
(vl-arx-import "AcApp.arx")
if running in separate namespace you have to import all functions that are of type EXRXSUBR
