Lee Mac Posted April 9, 2010 Posted April 9, 2010 Following this thread and this thread, I thought I'd write a complementary function to allow the user to operate on numbers inside text. Example: ;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,;;; ;;;ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,¤º°`°º¤;;; ;; ;; ;; ;; ;; --=={ Text Math }==-- ;; ;; ;; ;; The program will allow the user to perform mathematical operations on Text, ;; ;; MText, Dimensions & Attributes containing numerical data. ;; ;; ;; ;; The user is prompted to select an operation (Addition, Subtraction, ;; ;; Division & Multiplication); and an operand. The user is then prompted to ;; ;; make a selection of objects to modify. ;; ;; ;; ;; If a non-commutative operation is chosen, the user will be prompted to ;; ;; specify the order of operation. ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; FUNCTION SYNTAX: TextMath / TMA ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; AUTHOR: ;; ;; ;; ;; Copyright © Lee McDonnell, April 2010. All Rights Reserved. ;; ;; ;; ;; { Contact: Lee Mac @ TheSwamp.org, CADTutor.net } ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; VERSION: ;; ;; ;; ;; ø 1.0 ~¤~ 9th April 2010 ~¤~ º First Release ;; ;;...............................................................................;; ;; ø 1.1 ~¤~ 11th April 2010 ~¤~ º Updated to include Dimensions. ;; ;; º Updated ParseNumbers function. ;; ;;...............................................................................;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,;;; ;;;ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,¤º°`°º¤;;; Be careful when using with MText that contains nested formatting, comments are welcome. Lee --=={ Code Updated to Version 1.1 }==-- TextMath V1.1.lsp 1 Quote
Lee Mac Posted April 11, 2010 Author Posted April 11, 2010 Arghh! Will certainly get that fixed! Thanks mate Quote
alanjt Posted April 11, 2010 Posted April 11, 2010 (ParseNumbers "-1.5") (ParseNumbers ".3") I meant to mention it when you first posted. Quote
Lee Mac Posted April 11, 2010 Author Posted April 11, 2010 (ParseNumbers ".3") I meant to mention it when you first posted. That behaves as it should? Returns: ("." 3) Quote
alanjt Posted April 11, 2010 Posted April 11, 2010 That behaves as it should? Returns: ("." 3) I would think you would want 0.3 Quote
Lee Mac Posted April 11, 2010 Author Posted April 11, 2010 I would think you would want 0.3 But ".3" is not a valid number. Quote
alanjt Posted April 11, 2010 Posted April 11, 2010 But ".3" is not a valid number. Some people may type it that way. Command: (atof ".3") 0.3 Quote
alanjt Posted April 11, 2010 Posted April 11, 2010 Do what you will with the information. I just wanted you to be aware. Quote
Lee Mac Posted April 11, 2010 Author Posted April 11, 2010 Do what you will with the information. I just wanted you to be aware. OK, thanks. Quote
VovKa Posted April 11, 2010 Posted April 11, 2010 VovKa, please try Version 1.1 there is no need to try, i trust you Quote
Lee Mac Posted April 11, 2010 Author Posted April 11, 2010 there is no need to try, i trust you Haha... Quote
jammie Posted September 8, 2010 Posted September 8, 2010 Found this routine helpful last week, had to reudce a series of levels by a constant amount. The text contained both level info & characters, worked like a charm. It was simple to use & did exactly what it said on the tin Nice work on it Lee Quote
Lee Mac Posted September 8, 2010 Author Posted September 8, 2010 Thanks Jammie, I feel honoured that you could make use of it Quote
cport Posted January 24, 2014 Posted January 24, 2014 This program is VERY useful, but I need the ability to specify the number of decimal points the resulting solution generates (i.e. 710.75 - 0.25 = 710.50 not 710.5). It would also be useful to only modify text that fits a particular mask (i.e. ###.##) where there are multiple numbers within an object of text (i.e. 12" E. INV. = 734.44, I don't want to perform math on the 12" text). Any chance of a update with these features? Quote
yathishkumar Posted October 14, 2014 Posted October 14, 2014 good job i like it thank you very much Quote
LibertyOne Posted October 14, 2014 Posted October 14, 2014 5rd, 4nd and 3st --- I like it! But closing in on this dilemma, is there a clean way of getting that to work? 1st but 11th, 2nd but 12th, 3rd but 13th Hard to just take the number from the ones column. And what happens when you subtract 2 from 2nd? 0nd About 14 years ago, I wrote a couple of little functions for adding or subtracting 1, 10, 100 or your own amount to change numeral text and attributes. Quote
Lee Mac Posted October 14, 2014 Author Posted October 14, 2014 5rd, 4nd and 3st --- I like it!But closing in on this dilemma, is there a clean way of getting that to work? 1st but 11th, 2nd but 12th, 3rd but 13th Hard to just take the number from the ones column. And what happens when you subtract 2 from 2nd? 0nd About 14 years ago, I wrote a couple of little functions for adding or subtracting 1, 10, 100 or your own amount to change numeral text and attributes. Maybe that was a bad example for the demonstration, as this old program is really only intended to modify the numerical content in the text and does not attempt to interpret the surrounding non-numerical content. But where ordinals are concerned, perhaps the following function could be of use: (defun ordinal ( n ) (cond ((nth (rem n 10) '(nil "st" "nd" "rd"))) ("th")) ) _$ (ordinal 1) "st" _$ (ordinal 2) "nd" _$ (ordinal 3) "rd" _$ (ordinal 4) "th" Quote
