sandman007 Posted December 10, 2010 Posted December 10, 2010 I have been using your code for a week now and noticed that it splits the numbers with a comma is that one of the bugs that got worked out in the new code? Where can I get the reposted code... I really works excellent for quantities... Except for when they hit the thousands. Quote
alanjt Posted December 13, 2010 Author Posted December 13, 2010 I have been using your code for a week now and noticed that it splits the numbers with a comma is that one of the bugs that got worked out in the new code? Where can I get the reposted code... I really works excellent for quantities... Except for when they hit the thousands.Unrealized bug - never deal with commas in numbers, so didn't think of it. If I find some time, I'll work an update. Quote
sandman007 Posted December 14, 2010 Posted December 14, 2010 Awesome, I'm doing 7 subdivisions of concrete and paving improvements. Also would it be possible to have the selected items stay selected or to change color? We have a .lisp routine that adds acres from shapes/polygons/rectangles an when you select one shape it changes the color so that you know you have selected that one. I can send you the code it you need it. Quote
tanbqtb03 Posted October 31, 2012 Posted October 31, 2012 I have a really old routine that will add & subtract object values, but I was inspired by this thread to write a new one. Allows user to combine [Add, Divide, Multiply, Subtract] values of selected objects. User can also change mode (Add, Divide, Multiply, Subtract) at any time. When finished, user is prompted for placement point of MText with final value. If only Add option used, user has option to average values. Accepted: Attribute, Civil 3D Point, Land Desktop Point, MText, MultiLeader, Text or typed value. Call with CombineValues or AV. Your comments/criticism are greatly appreciated. Enjoy. ;;; ------------------------------------------------------------------------ ;;; CombineValues.lsp v1.2 ;;; ;;; Copyright© 04.09.10 ;;; Alan J. Thompson (alanjt) ;;; ;;; Contact: alanjt @ TheSwamp.org, CADTutor.net ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; The following program(s) are provided "as is" and with all faults. ;;; Alan J. Thompson DOES NOT warrant that the operation of the program(s) ;;; will be uninterrupted and/or error free. ;;; ;;; Allows user to combine extracted numerical values of selected Attribute, ;;; Civil 3D Point, Land Desktop Point, MText, MultiLeader, Text or typed value. ;;; ;;; Combine options include: Add, Divide, Multiply, Subtract (can be changed at any time). ;;; If user only adds values, an option to average is available. ;;; Upon completion, user is prompted to specify placement point MText with final value. ;;; ;;; Revision History: ;;; ;;; v1.1 (04.11.10) 1. Updated subroutine: AT:ExtractNumbers ;;; ;;; v1.2 (04.13.10) 1. Reworked AT:ExtractNumbers subroutine. ;;; 2. Added subroutine AT:ListSelect to select numbers when multiple exist in string. ;;; 3. If multiple numbers exist in string, user is prompted with list box ;;; to select each desired number. If multiple numbers are selected, they are ;;; combined and added to display. ;;; 4. Added CV:StripFormat subroutine, as taken from StripMText 5.0b, ;;; Copyright© Steve Doman and Joe Burke 2010 (with permission), to avoid any ;;; issues with extracting numbers out text formatting. (Thank you Joe & Steve) ;;; ;;; ------------------------------------------------------------------------ [ATTACH]18822[/ATTACH] Thanks for share but I can't see the dialog as your gif Quote
jedersonlobo Posted March 24, 2014 Posted March 24, 2014 First off all, congrats for the lisp, its great! I was wondering if its possible to define a specific value to the second number. Like, if i have group of topographic elevations of 1000.000m and i need to subtract 12m of all topographic points (text strings), how could i put this value (12m) automatic on the lisp. And if I already have the text string on the screen, if its possible to not put a new text, but just substitute the text string of the elevation. Quote
grants78 Posted May 23, 2014 Posted May 23, 2014 Thanks for the Lisp, its awesome for adding and subtracting One issue I can't seem to specify point with decimals without averaging value, Command shows true value. Is this an easy fix? Also can't multiple or divide decimal numbers. Cheers Quote
alanjt Posted May 23, 2014 Author Posted May 23, 2014 Thanks for the Lisp, its awesome for adding and subtractingOne issue I can't seem to specify point with decimals without averaging value, Command shows true value. Is this an easy fix? Also can't multiple or divide decimal numbers. Cheers I'm not sure I follow you. Could you give me an example? Quote
mousho Posted December 17, 2016 Posted December 17, 2016 (edited) ALANJT thanks for the lisp Edited June 9, 2020 by mousho Quote
mousho Posted June 9, 2020 Posted June 9, 2020 ALANJT thanks for the lisp its work like a dream there is away to change the selection by window and not one by one? Edited just now by mousho Quote
