searching for subtracting lisp
ayman
On 4/9/2010 at 3:25 PM, Lee Mac said:
Try this:
(defun c:subtxt (/ ParseNumbers GR NUM1 NUM2 P RES)
 (vl-load-com)
 ;; Lee Mac  ~  09.04.10
 (defun ParseNumbers (str / lst Num Aph x rtn)
   ;; Lee Mac  ~  20.09.09
   (setq lst (vl-string->list str) Num "" Aph "")
   (while (setq x (car lst))
     (setq lst (cdr lst))
     (cond (  (and (/= "" Num) (= 46 x))
              (setq Num (strcat Num (chr x))))
           (  (< 47 x 58)
                    rtn (cons Aph rtn) Aph ""))
           (t (setq Aph (strcat Aph (chr x))
                    rtn (cons (read Num) rtn) Num ""))))
   (vl-remove nil
     (vl-remove ""
       (reverse (cons Aph (cons (read Num) rtn))))))
 (mapcar
   (function
     (lambda (sym str / ent)
       (while
           (setq ent (car (nentsel str)))
           (cond (  (eq 'ENAME (type ent))
                    (if (wcmatch (cdr (assoc 0 (entget ent))) "*TEXT")
                      (if (not
                            (set sym
                              (car
                                (vl-remove-if-not
                                  (function
                                    (lambda (x)
                                      (vl-position
                                        (type x) '(INT REAL))))
                                  (ParseNumbers
                                    (cdr
                                      (assoc 1 (entget ent))))))))
                        (princ "\n** Text Must Contain a Number **"))
                      (princ "\n** Object Must be Text **")))
                 (  (princ "\n** Nothing Selected **")))))))
   '(num1 num2) '("\nSelect Text to Subtract from: " "\nSelect Text to Subtract: "))
 (if (and num1 num2
          (setq res (entmakex (list (cons 0 "TEXT")
                                    (cons 10  (getvar 'VIEWCTR))
                                    (cons 40  (getvar 'TEXTSIZE))
                                    (cons 7   (getvar 'TEXTSTYLE))
                                    (cons 50  (/ pi 2))
                                    (cons 1   (rtos (- num1 num2) (getvar 'LUNITS) 2)))))
          (setq res (entget res)))
   (while (and (= 5 (car (setq gr (grread 't 13 0))))
                 (listp (setq p (cadr gr))))
       (entupd
         (cdr
           (assoc -1
             (setq res
               (entmod
                 (subst (cons 10 p) (assoc 10 res) res))))))))
 (princ))
This lisp result how to place in End point
  • Replies 20
  • Lee Mac
    7
  • ayman
    6
  • alanjt
    3
  • Shaheensha976
    3
