poorestchump Posted April 8, 2010 Posted April 8, 2010 I don't know enough about vlisp to do this on my own. I've attached a dwg with dynamic blocks and a routine that numbers parts and totals the qty's. I need another routine that will find the distance from a stretch parameter created in the block editor so that only identically named parts with the same length will show up on the same line in a data extraction table. I can't find anything anywhere that shows how this might be done. Please help me:( Thanks in advance, jb junk.dwg 333.LSP Quote
ollie Posted April 9, 2010 Posted April 9, 2010 Hi The below code will set you on your way. Once you select a block it will list the attibutes and their corresponding values in the command line (vl-load-com) (defun c:gdi( / ) (setq ent (vlax-ename->vla-object (car (entsel "\nSelect block")))) (if(=(vla-get-hasattributes ent) :vlax-true) (progn (foreach att(vlax-safearray->list(vlax-variant-value(vla-getattributes ent))) (princ (strcat "\n" (vla-get-tagstring att) ": " (vla-get-textstring att) )) ) ) ) ) Hope this helps Ollie Quote
Lee Mac Posted April 9, 2010 Posted April 9, 2010 Here's one way to get Dynamic Block Properties: (defun GetDynProps (obj) (if (eq :vlax-true (vla-get-isDynamicBlock obj)) (mapcar (function (lambda (x) (list (vla-get-PropertyName x) (if (= 8192 (logand 8192 (vlax-variant-type (setq var (vla-get-value x))))) (vlax-safearray->list (vlax-variant-value var)) (vlax-variant-value var))))) (vlax-invoke obj 'GetDynamicBlockProperties)))) And another (defun GetDynProps (obj) (if (eq :vlax-true (vla-get-isDynamicBlock obj)) (mapcar (function (lambda (x) (list (vla-get-PropertyName x) (vlax-get x 'Value)))) (vlax-invoke obj 'GetDynamicBlockProperties)))) Quote
