SZLMCL Posted April 8, 2010 Posted April 8, 2010 Hy, I would like to draw an arc with AutoCAD VBA. Known the arc start- and endpoint, and the value of the bulge. With LWPolyline it is possible to draw an arc easily so (SetBulge), but i need draw the arc with ThisDrawing.ModelSpace.AddArc command. Here is not Setbulge function. (Addarc need StartAngle, EndAngle, Radius, CenterPoint). How can i draw it? Thanks! Quote
Lee Mac Posted April 8, 2010 Posted April 8, 2010 You can derive the necessary arguments from the definition of the bulge: Quote
Lee Mac Posted April 8, 2010 Posted April 8, 2010 In LISP: ;; BulgeData ~ Lee Mac ;; Args: p1,p2 Points, b Bulge ;; Returns: (<centre> <inc. angle> <radius>) (defun BulgeData (p1 p2 b / theta/2 radius centre) (setq theta/2 (* 2. (atan b)) radius (/ (distance p1 p2) (* 2. (sin theta/2))) centre (polar p1 (+ (- (/ pi 2.) theta/2) (angle p1 p2)) radius)) (list centre (* 2. theta/2) (abs radius))) Quote
SZLMCL Posted April 8, 2010 Author Posted April 8, 2010 You can derive the necessary arguments from the definition of the bulge: [ATTACH]18688[/ATTACH] Thanks, I managed to solve it in VBA. Quote
