skipsophrenic Posted August 22, 2008 Posted August 22, 2008 HELP! Just had my computer at work upgraded from AutoCAD 2004 to 2008. Once the installation was complete, i went to customise the layout as am stuck using 1 screen, however now since the upgrade, whenever I press the mousewheel down I get the right click custom menu instead of being able to pan, and i can't double-click to do a zoom extents, :cry: does anybody know how to set a mouse up so it will go back to pan nd zoom and not menu's??? Quote
Strix Posted August 22, 2008 Posted August 22, 2008 I think you may need to change that in your windows settings Quote
skipsophrenic Posted August 22, 2008 Author Posted August 22, 2008 n e body know how to do that? Quote
eldon Posted August 22, 2008 Posted August 22, 2008 Have you checked the system variable MBUTTONPAN? It should be set at 1 for panning whilst holding the wheel down. Quote
skipsophrenic Posted August 22, 2008 Author Posted August 22, 2008 Have you checked the system variable MBUTTONPAN? It should be set at 1 for panning whilst holding the wheel down. thanks! that's done it Quote
nocturne00 Posted August 23, 2008 Posted August 23, 2008 Have you checked the system variable MBUTTONPAN? It should be set at 1 for panning whilst holding the wheel down. Nice, thats another system check for standard acad settings. thanks man Quote
