Autocad 2010 Structural Steel Detailing Tutorial
Can anyone tell me how to get a structural steel tutorial for autocad 2010 or 2005. please I'm a beginner, i wanna get into steel detailing.thanks for your help.
Just what is it that you want to learn? How to detail steel connections?
REMARK, well i wanna learn how to detail the structural steel parts,i know all about the materials(angles,beams,tubes,etc.)what i wanna learn is how to detail like connection plates.basically like the detail on a print,like for example @ my work they give a print and i start fabricating the part(beams or structural shapes),but this whole part has loose parts(detail) and that's what i want to learn how to draft the detail.Connection plates with holes.can you help me.
Thanks Tankman for the link, I know about dimensional data in my head.
Thanks for your help anyways.
dannysteel, exactly how I got started drawing and then AutoCAD!
If you know the dimensions, plates, weldments, shapes, you can draw as built.
Start drawing!
The Manual of Steel Construction - Volume II Connections might be of some help. Some topics covered are bolted connections, simple shear connections and moment connections.
  • 9 months later...
