Get dwg unit in lisp (metric/imperial)
I have a custom leader lisp that draws a leader perfectly if the dwg is metric. When the dwg is imperial, the leader head is 25.4X smaller. Is ther a way to check for drawing units on the lisp? and then scale the leader head 25.4 times?
;;;Conduit Leader;;;
(defun c:cld ( / )
 ;;store orig error handler, assign new error handler
 (setq OrigError *error* *error* *InsError*)
 (command "-insert" "cleader");****** the cleader.dwg must be in one of the support path for it to work!******
 (command);;cancels the insert
 (setvar "dimldrblk" "cleader")
 (setvar "texteval" 1)
 (prompt "\nCLeader")
 (setq CL (getvar "clayer"))
 (c:setlayer "E-ANNO-TEXT")
 (command "_.qleader")
 (while (> (getvar "cmdactive") 0);;pauses while command is active
      (command pause)
 (setvar "dimldrblk" ".") ;;restore arrowhead
 (setvar "clayer" CL);;restore layer
 (setq *error* OrigError);;restore default error handler
;;---error handler for routine-------
(defun *InsError* (msg)
   (princ (strcat msg " ** CLeader Terminated **"))
   (if CL (setvar "clayer" CL));;restore layer
CLeader.dwg
(getvar "LUNITS")
Hmm...LUNITS only tells me if it's:
1 Scientific
2 Decimal
3 Engineering
4 Architectural
5 Fractional
It doesn't tell me if the dwg is metric or imperial.:(
(getvar "MEASUREMENT") will return 0 for imperial units and 1 for metric.
Thanks. I got it now.:D
To VovKa
I see you posted the same answer just with one minute later as I did. There is no need to delete your own post. This forum is full of duplicate answers.
ok, thanks fuccaro, i'll do as the ancients said - "Repetitio est Mater Studiorum" :)
