Thank you for your gratitude, I'm delighted that you find the program useful!
In response to your request, please refer to this post earlier in the thread.
Lee
sorry, I miss it.
PERFECT, AS USUAL!! :lol::lol::lol::lol:
  • 2 weeks later...
Hi Lee,
I'm using this lisp for more than one year. And it's one of my favourite lisp. But today I got an error as "** Error: Automation Error. Problem in loading application **". How can I solve the problem, do you have any suggestion?
Thanks Lee for fast reply,
RegisterObjectDBX didn't resolve the problem but finally I clean uninstall/reinstalled the Autocad and it works now. :)
Excellent to hear! :)
  • 2 weeks later...
Where are the saved searches files located? Are they in .txt format? I would like to edit off line so I can copy and paste from excel a multiple line entries. Thank you.
Please refer to this post.
  • 6 months later...
hey lee, hope you fine...
thanks a ton this great routine!
i have some advices to you for next versions :)
f&r progress in order?
and
savelist export and import? (from a txt)
sorry for bad english, c'ya :)
Thank you for your suggestions - I'm glad you find the program useful. :)
  • 3 weeks later...
Lee, I was wondering if someone else has already reported the bug that the report file wouldn't be generated when user is doing a SEARCH ONLY batch. Or maybe I am wrong and the report is only meant to be generated only if there is Replacement batch?!
Edited by bababarghi
The report should always be generated for a 'Search Only' run, but will only be generated for a replacement run if the 'Always Generate Replacement Report' option is enabled.
The report should be created in the same directory as the processed drawings (if write-permissions allow this).
I am afraid that's not the case on my machine then ! The write permission is granted on the drive which drawings reside. The program runs without any problem and I see the console message which states that XXX drawing processed but no Excel file would be generated :unsure:
EDIT:
It doesn't create the excel report because the research result is NONE (no instance of keyword exist in searching directory). I think the code should still create a and open a blank report regardless. Don't you think Lee?
  • 8 months later...
Lee Mac, first thank you for your amazing lisp routines, I use them often.
I am having an issue with the Batch Find & Replace. I type bfind, and the window comes up. It shows the last info I did a find and replace from, however when I enter in new info to find and replace and hit OK, the window goes away and nothing happens. If I open bfind again, it still shows the old info. I can't figure out what is going on.
Any ideas?
  Lee Mac said:
What is the command-line output received?
According to the text window, this is what I'm getting:
Command: BFIND
Select Object:
Working, Please Wait...
I have tried deleting and unloading the lisp, then downloading a new copy but it still keeps the old info in the find and replace boxes.
Command: BFIND
Select Object:
From the error message you are receiving, it would seem that the ObjectDBX DLL required by the BFind program is not found or registered on your system; ObjectDBX is the technology which is required to interface with a drawing without opening the drawing in the AutoCAD Editor – it is provided with the standard AutoCAD installation.
The attached program (RegisterObjectDBX.lsp) will attempt to automatically find & register the required DLL module if found on your system – the command for the attached program is regodbx. The program should also print some diagnostic messages to the command-line when run.
After running the program, please restart AutoCAD and try my BFind program again – if this remains unsuccessful, I could only unfortunately suggest an AutoCAD reinstallation to attempt to resolve the problem.
Lee
RegisterObjectDBX.lspFetching info...
Unfortunately that didn't work (was returning nil). I did get it working again however. Last week I installed Advanced System Care (which I have done many times, just not on my newest computer), and ran a cleanup. I figured that may have been the culprit and did a rollback to before I installed it and now it works just fine. Now I know not to use that again.
Thanks for your quick responses, as always, thanks for your great list of addons for AutoCad since it truly does make my work easier.
