  • 3 months later...
Dear Lee Mac
Thanks for the sharing the program. I can see your hard work, as I am now trying to develop a routine for multiple Find and Replace using excel VBA (just started). I was trying to replace the Mtext that is in Japanese language with the equivalent English text. Japanese language fonts are in Unicode unlike the English fonts that are in Ansi encoding.
Meanwhile, I got this error when trying to make a multiple find and replace. I used the version2 lisp file from - http://lee-mac.com/bfind.html
Command: bfind
Working, Please Wait....
** Error Processing Drawing: Sample.dwg **
** Error Detail: Win32: No mapping for the Unicode character exists in the
target multi-byte code page **Regenerating model.
Command:
Command:
One of the reason is that my system locale is set to Japanese. So, I changed that to English. Still was not able to make the find and replace. I get this error even when I find to replace even a simple English text.
Command: bfind
Select Object:
Working, Please Wait....Regenerating model.
Command:
Command:
For example, when I click this button >> for Find_what and select this text "プレート取付ケ状態" in the drawing, i get the following "{\W0.844962;プレート取付ケ状態}" in the Find what text box. I am not sure what this "\W0.844962;" is, and may be it is related to Japanese font (Unicode font). I am getting some sort of text whenever I select a Japanese text.
When I use the AutoCAd inbuild Find function to Find and Replace single text, it is working without any issue. I am not sure why I am not able to make any replacement using your program. Try to guide me when you are free.
When working on your program, I find some other things. Don't feel that I am asking for too much. You once said in one of your reply that this program would not have come to this level if not for the users comments. Based on that I am giving the following comments and suggestions though not all are required for me at this moment. I will be very happy to test your beta version of the program.
Bug
1) The program allows me to add 2 different "Replace with" for the same "Find what"
Find what Replace with
Sample aaa
Sample bbb
This should not be allowed. Some sort of checking the previous entries should be done before adding a new set of text
2) I am also able to add the same text for "Find what" and "Repalce with". This shall be avoided with some check.
Sample New Text
Sample New Text
Some other improvement
1) Saving in DXF format: I checked this thread: http://forums.augi.com/showthread.php?t=132331
So I guess that even inserting something like this within your program wouldn't work?
(vla-get-saveastype
(vla-get-opensave
(vla-get-preferences
(vlax-get-acad-object)
SaveAsType
acSaveAsType enum; read-write
ac2007_dwg
AutoCAD 2007 DWG (*.dwg)
That is changing the save settings in the Options for the Active Document, and hence will not affect the ObjectDBX Document.
I am not able to understand the meaning of your reply. If it is possible to save in older version for the current drawing, can you provide that when the "Current drawing" option is selected. That is a combo box should appear where the users can select the version they can save the file for the current drawing and it shall remember that.
2) If search only option is clicked, then it should deactivate the Replace window. I was trying the find and replace for few time with the search only option checked by mistake.
3) When I save a list, it shall give the location where it is saving the file just below the "Save as" dialog box.
4) When batch replacement is made, you may add some text like "Saving the file in (current version)"
5) When "Current Directory" is clicked, then it should erase the previous folder selected through the "Directory" option. Otherwise there will be confusion for the user, on the folder for replacement.
6) When "All open Drawings" is clicked, the number of open drawing shall be displayed. This will be caution for when the user is unaware of the number of opened drawings.
7) The length of Directory display shall be increased as it is showing partially. May be you need to provide multiline text to show the full path. I think you should use the word "Drawing folder" instead of "Drawing Directory" in the frame as Folder is the common usage. You may prefer the change the name of button from "Directory" to "Browse". The function of the button is Browse and that is the common usage.
8) You may change the name of "Current drawing" to "Active drawing" (I am telling this from vba syntax and not sure of the LISP syntax).
Regards
Chandru
I know you had an issue with MText shifting but I have a case of the first line being repeated and I cant figure out why.The attached drawing has the text I am trying to replace. I want to replace the #BR1 - #BR6 with other values but when I try to do this I get the first line repeated in every instance of this type of text. Am I doing something wrong with the program or is there a way I can fix this?
Thanks for your help.
BFIND_Issue.dwgFetching info...
Hi Chandru,
Please see the replies to your comments below:
Command: bfind
Command:
Command:
I have developed the program to work with ASCII character encoding and haven't incorporated support for Unicode characters.
Command: bfind
Select Object:
Command:
Command:
This isn't an error, the program is just indicating that no replacements have been made in the drawing, most likely because the 'Find' string could not be found in any of the selected objects to be searched.
The "{\W0.844962;" is an MText formatting code (not related to the Unicode characters), these formatting codes are present in the text string whenever formatting is applied to objects using MText (MText/MLeaders/Dimensions etc.).
In the next version I shall implement code to remove the formatting codes when displaying selected text in the dialog.
Because my program does not use the inbuilt AutoCAD Find function.
  Chandru said:
Bug
Sample aaa
Sample bbb
Well spotted, I shall fix this in the next version.
Sample New Text
Sample New Text
Same as above.
(vla-get-saveastype
(vla-get-opensave
SaveAsType
ac2007_dwg
ObjectDBX only will permit saving to the native version (i.e. the highest version available in the application in which the program is being used). Changing the SaveAsType property will have no effect on the ObjectDBX document, since this property only changes the default save version in the Options Dialog.
I do not intend to add extra options that are only available for some selected drawings.
No it shouldn't. Otherwise the user cannot add 'replace' strings and so cannot see the 'preview' of the replacement operation in the CSV report, which defeats the point of having this functionality.
I feel the program should handle the data storage, and the user should use the dialog interface to access the stored lists, not the inner workings of the program.
However, I may add an 'Edit' button to a future version so that the saved searches file may be edited manually.
Thank you for the suggestion.
The directory should be 'greyed out', indicating that only the current drawing will be processed; but perhaps erasing the text could be clearer.
I considered adding a line beneath the toggles in the Drawing Directory panel to display the number of drawings to be processed for the selected directory / selected toggle settings; however, if the user unexpectedly sets 'Include Subdirectories' for a high-level root directory, the program will needlessly scour many directories just to display the number of drawings.
A difficult one since the directory could be very long indeed for different users - but I agree that the display could be increased.
I agree that the button should be 'Browse', but I intend to keep the term: 'Directory'.
I feel that 'Current Drawing' is more applicable to the majority of non-programmer users that will more likely be using the program.
Thank you for your detailed feedback Chandru, it is greatly appreciated, I now have many ideas and bug fixes to implement in the next version.
Thanks
Lee
Hello,
I've implemented BFind Ver 2-0 due to I find it useful judging from description. In fact I have to change only title block in every single of my 130 drawings. I wanted to prepare such list in Excel and have stored as text. I cannot find the file mentioned - Acad gives me answer (nil) also for (findfile "LMAC_BFind_SavedSearches_V2-0.txt"). Please assist.
Thanks in advance.
  Lee Mac said:
The find/replace string saved searches are stored in the file in this location:
type at the command line:
(findfile "LMAC_BFind_SavedSearches.txt")
As for the Find Only: tick the 'Search Only' box.
  _Atilla_ said:
Hello,
Thanks in advance.
The file will only exist if you have already saved some searches. Run the program, add a few search/replace strings, and click Save. After saving, cancel the main dialog and attempt to find the file.
Lee
Lee, thank you for prompt answer. Still no result - I cannot find that *.txt file however lists are stored somewhere because I can read them under BFind dialog display. Additional thing is that AutoCAD 2008 is installed on C:\. I don't have "write" permission to that disc. Some other configuration files are placed on network drive (e.g. Acad.pat) to which i also have no write permission. Only custom configuration files I have on my D:\ local drive which I can modify. Maybe that might be a reason. Nevertheless I've searched "My computer" so network drives inclusive for any *BFind*.txt files with no results - strange to me and a pity. Please assist.
_Atilla_
Lee
Have a look in the directory stored by the ROAMABLEROOTPREFIX System Variable.
Lee,
that solves everything - I couldn't find it due to it's hidden folder. Anyway - problem solved - thank's a million.
Regards,
_Atilla_
  _Atilla_ said:
Lee,
Regards,
_Atilla_
You're very welcome _Atilla_ :)
As an aside: My initial intentions were to have the program handle the loading/saving of the search/replace strings, with the user manipulating the content solely through the dialog interface. But in the next version I may add an 'Edit' button to the Load dialog to open the .txt file in which the search/replace strings are stored for manual editing.
Lee
  • 1 month later...
Hi Lee,
the lisp works great but I have found one minor issue and I don't know if it is linked with doing a heavy load of batch replacing but I am finding that the text that gets replaced is getting shifted to the right. I thought maybe the justification was getting changed since it looks like the result of left justifying a centered text but after checking I still find my text is set to centered.
Have you noticed this at all?
Hi taka,
Unfortuately this is a known bug when modifying text strings with ObjectDBX that ADesk haven't fixed. I have included a subfunction in the program to attempt to counter the shift in position, but this may not work in all cases.
Lee
  • 1 month later...
Hi Lee.
I Think i found a new bug. if you search for character "{" or "}" it will not find it. It's Odd. :?
You're right, it won't find curly braces - this appears to be a result of how the replacement engine in the program handles MText formatting codes - not an easy one to fix I'm afraid.
Thanks for Reply
Actually i'm using your perfect program for another purpose :)
I have many files with shx font and want to use your program to convert them to TTF. unfortunately some original characters are "{" or "}" and Bfind ignore them. I am building a new character map by using "LMAC_BFind_SavedSearches.txt". I'll be Appreciate if you help me to go through this problem.
Hi, Lee
I've find that errors with using BFindV2-0.lsp with the condition of chinese version XP system & Autocad2010 English version.
Command: bfind
** Error Processing Drawing: 62-100-D-04.dwg **
target multi-byte code page **.
It seems like activex automation errors.
Thanks.
Xia
Hi Xia,
I have designed BFind for use with ASCII characters, I cannot guarantee that it will work with Unicode characters.
Lee
  • 3 weeks later...
Hello
There are ideas for improving your program's functionality Bfind
1) Make a choice of the filter Layer for replacement text
2) Make a selection file with the table replace text in txt format or Excel
Can you make these changes to your program?
Thank you.
P.S. Sorry for my English :)
Thank you for your suggestions Arkon :)
I haven't worked on this program for some time, however, I shall keep your ideas in mind for the next version.
Lee
