neekcotrack Posted August 21, 2008 Posted August 21, 2008 Ok I would say this is my first from scratch lisp that I have done. What It does is it will only work if I pic the 122x34 sheet size but if I pick any of the other once. I know the code it fine, I have tested it individually. If anyone can help with getting it to work I would appriciate it. I think its just some missing (). Also if you have any suggestions on ways to make it shorter if possible. Plus I was want to add a custom option but the will be later in this forum I hope. Code is zipped and attached. Thanks in advance for everything!!! Quote
