envirotronix Posted August 21, 2008 Posted August 21, 2008 Hi everyone, first timer and Newbie here. Just starting out in the ACAD world... been a Visio guy for a while. Just received a DWG file with a floorplan that contains Fire Alarm devices on it. It opens fine in AC but, I *can't* seem to pick any object. Hovering over or directly selecting any object, makes No change? I've got the current layer selected, unfrozen, unlocked, open - thru layer manager, but just can't select anything. I can change the color of all objects within the layer but can not select a specific object or group of objects. It's almost as if the file is protected from any changes. Tried various changes, even added/moved/resized my own objects without any problem, but the original objects just remain untouchable??? So, what simple thing am I missing here??? Thanks in advance, John Quote
dbroada Posted August 21, 2008 Posted August 21, 2008 you could be in paper space. do you have a tab at the bottom of the screen with MODEL on it. If so press there and try again. Quote
envirotronix Posted August 21, 2008 Author Posted August 21, 2008 Dave; You nailed that one over the fence. Yes, it appears that I was in fact in the wrong layout space. In my case, I have buttons along the bottom/middle which allowed me to change space and make the edits. Thanks for your quick reply. John Quote
