How to make a circle half solid? Please anyone?
I am using Autocad 2007 for school and for some reason can not figure out how to make a circle half solid.
So I have my circle and I want half of it solid and half of the circle not solid. I know this is probably a silly question but I just can not figure it out.
Thank you for the help.
draw a line across the diameter of the circle & then select which half you want to hatch as solid.
draw a circle then draw a line using quadrant snaps. then copy the circle with the line and trim your circle.Polyedit the half circle and line so you can extrude it to become a solid.Is PRESSPULL available in '07?
Thank you both so much for answering so quick. I just tried the hatch and it seems to work perfect. Thank you both again so much, you are lifesavers.
Glad to hear we saved a life today :wink:.
