hi i am using autocad 2009, how can i justify some text inserted from VBA in autocad drawing. i want to make it justified MIDDLE CENTRE.
You should insert the text entity and just after alter his alignment; the code below may clarify this:
Dim myTextObject As Object
Set myTextObject = ThisDrawing.ModelSpace.AddText("Hello World!", TextInsertionPoint, 1#)
'modify text alignment to Middle-Center
myTextObject.Alignment = acAlignmentMiddleCenter
Please check the help for the list of built-in alignment constants.
Regards,
