Hi all,
I have a CUI file include toolbar and menu with name mycuifile.cui, when i use a scrip file with command
(command "_menuload" "C:\\mycuifile.cui")
Autocad load toolbar only, it can't load menu
why?
thanks for support! :)
thanks but it can't load menu, too.
But when i type (command "_menuload" "C:\\mycuifile.cui") in command line, it work correct
Autocad load toolbar and menu
you may try this one.
(defun c:loadit	(/ cui_database mnbar flag)
 (vl-load-com)
 (setq	cui_database
 (list
   "EXPRESS"			[color="Blue"];<<< MENUGROUP[/color]
   "C:\\Documents and Settings\\Ronald\\Application Data\\Autodesk\\AutoCAD 2008\\R17.1\\enu\\support\\acetmain.cui" [color="blue"];<<<PATH & CUI FILENAME[/color]
   "E&xpress"			[color="blue"];<<< MENUNAME[/color]
) ;_ end_list
 ) ;_ end_setq
 (vlax-for n
      (setq all_menus
	     (vla-get-MenuGroups
	       (vlax-get-Acad-Object)
	     ) ;_ end_vla-get-MenuGroups
      ) ;_ end_setq
   (if	(= (vla-get-name n) (car cui_database))
     (setq flag T)
   ) ;_ end_if
 ) ;_ end_vlax-for
 (if (null flag)
     (vla-load
all_menus
(cadr cui_database)
     ) ;_ end_vla-load
     (setq MnBar
     (vla-get-MenuBar
     ) ;_ end_vla-get-MenuBar
     ) ;_ end_setq
     (vla-InsertInMenuBar
(vla-Item
  (vla-get-Menus
    (vla-Item
      (vla-get-MenuGroups
      (car cui_database)
    ) ;_ end_vla-Item
  ) ;_ end_vla-get-Menus
  (caddr cui_database)
) ;_ end_vla-Item
(1- (vla-get-Count MnBar))
     ) ;_ end_vla-InsertInMenuBar
   ) ;_ end_progn
   (princ "\n>>..MENU IS ALREADY LOADED..<<")
 ) ;_ end_if
) ;_ end_defun
Thanks for your support, it work correctly. But I want to use scrip file to add my menu and toolbar in Cad on another PC. That cui file is a share file.
Can you help me? Thanks!
in your scr file, you may have this:
;;;Point the script to the location of the loadit.lsp
(load "c:\\completepathhere\\loadit)
;;;then run
(c:loadit)
you may also need to add additional support paths for your menu to work correctly in another computer.
i think so, thanks for your support!
When i use command cuiunload in my scrip to unload my cui file, it's only unload menu and toolbar on screen. partial cui file in CUI interface is not unload. when i restart ACAD it show toolbar again. Why?
Thanks for support.
try this:
[color=navy](defun c:unloadit ()[/color]
[color=navy](vl-load-com)[/color]
[color=navy](vla-unload (vla-Item (vla-get-MenuGroups (vlax-get-Acad-Object)) "EXPRESS")) [/color][color=darkorange];...<<< MENUGROUP [/color]
[color=navy](princ)[/color]
[color=navy]) ;_ end_defun[/color]
Thanks, but it used like command "cuiunload" cui file in CUI dialog is still there
using acad09 here, this one works fine here:
(command "._cuiunload" "Express")
  • 4 years later...
 (vl-load-com)
 (setq	cui_database
 (list
) ;_ end_list
 ) ;_ end_setq
 (vlax-for n
      (setq all_menus
	     (vla-get-MenuGroups
      ) ;_ end_setq
     (setq flag T)
   ) ;_ end_if
 ) ;_ end_vlax-for
 (if (null flag)
     (vla-load
all_menus
(cadr cui_database)
     ) ;_ end_vla-load
     (setq MnBar
     (vla-get-MenuBar
     ) ;_ end_setq
(vla-Item
  (vla-get-Menus
    (vla-Item
      (vla-get-MenuGroups
      (car cui_database)
    ) ;_ end_vla-Item
) ;_ end_vla-Item
   ) ;_ end_progn
 ) ;_ end_if
) ;_ end_defun
wizman, your code really works for me and that was what i am looking for a long time, thanks for that but, I have to ask some modification because I try to modified coz what I need is for more than 1 menu name(actually I have 3)..
I tried to, but it wont work for me.. can u please?????
  • 6 months later...
Yes, this.
I've been using this for almost a year, but now I need to load our company's CUI and XL2CAD's CUI. I also tried to modify to accept multiple CUIs, but was unsuccessful.
