get closest intersection point
Gringo
    (setq PT1    (vlax-curve-getPointAtDist BotObj stepLength))
(setq PT2
   (vlax-curve-getClosestPointTo
     UpperObj PT1)
  (setq Xline (vlax-invoke acSp 'AddXLine PT1 PT2))
  (setq PT2 (vlax-invoke  Xline 'IntersectWith UpperObj 0))
Ok this is part of a code i got to get the intersection point of a line through two lines - BotObj & UpperObj
it is sometimes setting the the PT2 as the further intersection point.
How do i make sure PT2 is the closest intersection point of 'UpperObj' from PT1??
I assume you may know of (DISTANCE pt1 pt2) and then compare between two other points?
