Dana W Posted April 5, 2010 Share Posted April 5, 2010 If the text you want to put in the slot, box, etc. wont fit, can you stretch/edit the block? And if so, where are these blocks located? I don't see anywhere inside the command to do this.Glenn 2009LT They are in the design center, Folders, Multileader tools dwg. They are separate entities from the multileader of course. The text is a tag, and even though it says it is mtext, it will not edit inside the block editor for me. It will move around though. I don't know very much about this feature, so I am treading in dark water here. Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted April 5, 2010 Share Posted April 5, 2010 They are in the design center, Multileader tools dwg. But just insert a multi-leader someplace, select the block attached to the leader and open the block editor just to see what is inside it. The text is a tag, and even though it says it is mtext, it will not edit inside the block editor for me. It will move around though. I don't know very much about this feature, so I am treading in dark water here. Wow, that's great. I just learned two things. How to list the blocks and edit them at the same time. Thanks again. Don't go crabbing, we need you here. Glenn Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 5, 2010 Share Posted April 5, 2010 Wow, that's great. I just learned two things. How to list the blocks and edit them at the same time.Thanks again. Don't go crabbing, we need you here. Glenn NO, I need me here. I have put my foot in my post about 50% of the time on this forum but I am learning a great deal. I have to curb my enthusiasm a bit so I won't cause any damage. Maybe I'll try sponge diving in the Virgin islands instead. Quote Link to comment Share on other sites More sharing options...
