t1320t Posted March 8, 2010 Share Posted March 8, 2010 Hey all- I've been searching around for a while to no avail. I'm trying to the use the sidebar flyout that has a tool called "Leader - Circle". When I use it the text is always in Romans font. Current Text Style is not Romans, current Dim Style does not have Romans associated with it, current Multileader Style does not have Romans associated with it. What controls the text style of the "Leader - Circle" tool?? Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 The setting is in multileader styles. Select the leader style you want to use and modify it or create a new one. Look in the Content tab and where it says type select mtext. It will have boxes below it to select the font style you want to use. Then if you want a bubble go back to multileader type and pick block, then select the circle. That should do it. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 Thanks Ryder76... that did the trick. I had it set to mtext but didn't try switching it to block, that fixed it. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 Glad to help. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 I've been playing w the command but can't find a way to control the dimgap. Is there any way to control it or is it fixed? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 8, 2010 Share Posted March 8, 2010 Did you try typing DIMGAP at the command line and resetting it? Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 Yep, that was the 1st thing I tried. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 When you say DIMGAP do you mean the distance between the leader landing and the text that follows? In the multileader styles, go modify, Leader Structure tab and see Landing settings. Or what you need may be under Leader Format tab, Leader break. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 Yeah, that's what I was referring to when I said DIMGAP. I'd like to be able to tighten the gap between the text and the circle/hex/triangle. I adjusted both of those variables & neither seemed to affect it. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 On the Leader Structure tab try de-selecting the button that says Automatically include landing and see if that does it. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 Also back to my first post - Under "Content" if you select Mtext a window shows up and at the bottom where the Leader Connection area is you will see Landing Gap. Try changing the setting there and then change your type back to circle - see if that does it. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 No dice. Thanks for the suggestions. When I de-select that, it eliminates the prompting for a landing distance when I fire up the command. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 Just keep monkeying around in there. I'm sure you will find it. I always create a new test style while I'm fiddling with something. Then when I get it figured out I set a standard name for it. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 8, 2010 Author Share Posted March 8, 2010 I'll keep messin with it for a little while longer. If I figure it out, I'll post my settings. Quote Link to comment Share on other sites More sharing options...
rkent Posted March 8, 2010 Share Posted March 8, 2010 What Ryder suggested works here, Content tab, Horizontal attachment, Landing gap, set to smaller value. I have 2010, that might be the difference. Quote Link to comment Share on other sites More sharing options...
Ryder76 Posted March 8, 2010 Share Posted March 8, 2010 I'm running 2008 and have the same selections. Quote Link to comment Share on other sites More sharing options...
t1320t Posted March 9, 2010 Author Share Posted March 9, 2010 I'm using 2009 & have the same options also with the exception of the Horizontal attachment and Vertical attachment under Leader connection. Quote Link to comment Share on other sites More sharing options...
t1320t Posted April 1, 2010 Author Share Posted April 1, 2010 I still haven't figured how to modify the gaps.... any ideas?? Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 3, 2010 Share Posted April 3, 2010 Look at the block for the circle, box, triangle thingy. Maybe the block editor will show you what's wrong. I took a look in my 2009 and can only change the position of the text, at least as far as I can tell. Maybe this will give you an idea anyway. I thought it may have something to do with the alignment or insertion point of the text object itself. Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted April 5, 2010 Share Posted April 5, 2010 Look at the block for the circle, box, triangle thingy. Maybe the block editor will show you what's wrong. I took a look in my 2009 and can only change the position of the text, at least as far as I can tell. Maybe this will give you an idea anyway. I thought it may have something to do with the alignment or insertion point of the text object itself. If the text you want to put in the slot, box, etc. wont fit, can you stretch/edit the block? And if so, where are these blocks located? I don't see anywhere inside the command to do this. Glenn 2009LT Quote Link to comment Share on other sites More sharing options...
