How to select blocks by (block)name in the Model Space with VBA?
Thx,
And How to create Acad Selection Sets by block name?
Creating a filtered selection set of all the BlockReferences of a particular name would look something like this:
Sub GetNamedInserts()
  Dim entbref As AcadBlockReference
  Dim TempObjSS As AcadSelectionSet
  Dim intCode(2) As Integer
  Dim varData(2) As Variant
  Dim strName As String
     strName = ThisDrawing.Utility.GetString(0, "Enter Block name to select: ")
     SSInit
     Set TempObjSS = ThisDrawing.SelectionSets.Add("TempSSet")
     intCode(0) = 0: varData(0) = "Insert"
     intCode(1) = 67: varData(1) = 0
     intCode(2) = 2: varData(2) = strName
     TempObjSS.Select acSelectionSetAll, , , intCode, varData
     MsgBox "There are " & TempObjSS.Count & " inserts referencing " & strName & " in Modelspace"
End Sub
Sub SSInit()
Dim SSS As AcadSelectionSets
Dim SS As AcadSelectionSet
  Set SSS = ThisDrawing.SelectionSets
     If SSS.Count > 0 Then
        For Each SS In SSS
           If SS.Name = "TempSSet" Then
              SS.Delete
              Exit For
           End If
        Next
     End If
End Sub
Also be aware that filter data can also include wildcard characters to allow for broader selection. So, for instance, if the filter was:
intCode(2) = 2: varData(2) = strName & "*"
and strName was “Block”, then the selection set would include inserts referencing “Block1”, “Block2”, “Block3”, etc.
Aren't we able to do this with filter or QSELECT?
Absolutely.
Conceivably, though, a useful VBA routine would process the selection set beyond just returning the count.:)
     SSInit
End Sub
Sub SSInit()
        For Each SS In SSS
              SS.Delete
              Exit For
           End If
        Next
     End If
End Sub
Thx,
And how to Zoom to the selected Block in the ModelSpace?
