civil_graham Posted February 25, 2010 Posted February 25, 2010 I recently used the Turbo lisp app to make my autocad run faster. When using it it makes the command line text red. I have since unloaded it, but the text still shows up red after restarting. How do I change it back to black without losing all of my other settings? Quote
civil_graham Posted February 25, 2010 Author Posted February 25, 2010 Never mind, fixed it right after... Quote
nukecad Posted February 26, 2010 Posted February 26, 2010 So please share the fix in case anyone else has the same problem. Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 You can change the colors from Options. Quote
civil_graham Posted February 26, 2010 Author Posted February 26, 2010 You can change the colors from Options. [ATTACH]17705[/ATTACH] That is all I used to change it back, I was assuming that the lsp changed other settings that would override the options. Quote
