Intermitent AENEXT
Does anyone else have a problem with AENEXT working sometimes and not others? I have a macro button that I wrote that saves a drawing and then calls the AENEXT that is built into ACAD Electrical, which should open the next drawing in the active project. It works about 50% of the time. About 90% of the rest of the time, simply hitting the arrow button in the ACE: Main Electrical II toolbar will move me to the next drawing. the rest of the time, I just have to close the drawing and open the next one manually through the Project manager.
I believe that I am current on all service packs and hot fixes.
Thanks,
Glen
  • 2 weeks later...
Hello glen, I used to have the same problem and I couln't fixed until I changed my settings to SDI 1. If I have the SDI 0, I will have the problem that you have. I hope this would help you solve you problem.
