startpt endpt - rotation angle??
if i have a start point and a end point of a line stored how do i get the rotation angle of that line within lisp??
I've not done any lisp for a long while but here is some VBA code that will record the angle of a line. Open or create a drawing with a line in it then
open your VBA editor (Alt F11) and create a new module and add the following sub LineTest to the module and run it.
Public Sub LineTest()
Dim oAcEntity As AcadEntity
Dim oAcLine As AcadLine
 'search all entities for a line object
 For Each oAcEntity In ThisDrawing.ModelSpace
   'find the 1st line object in the current drawing
   If oAcEntity.ObjectName = "AcDbLine" Then
     'record the line
     Set oAcLine = oAcEntity
     Exit For
   End If
 Next
 'declare a variable to hole the line angle
 Dim ThisLineAngle As Double
 'convert radians to degrees
 ThisLineAngle = oAcLine.Angle * 180# / 3.14159265
 'print the value
 Debug.Print ThisLineAngle
End Sub
Hope this works for you. I'm sure someone will send you a lisp reply...
(angle pt1 pt2)
where pt1 and pt2 are star and end points in (x y z) list form. This will give you the angle in radians relative to the current UCS.
yes thanks kindly - i dont have the help guide here at home..cheers for that
i ended up using
(setq a (list (car startpt)(cadr startpt)))
(setq b (list (car endpt)(cadr endpt)))
(setq ANG (angle a b))
Cheers mate
i ended up using
Cheers mate
If a and b are nothing more than place holders then do this instead:
(setq ANG
If you are using them later then the way you have it is fine.
$.02
