ReMark Posted August 12, 2016 Posted August 12, 2016 There really is no good reason to put anything on the Defpoints layer that doesn't belong there since the introduction of being able to set a layer to "no print" in the Layer Property Manager. Quote
rkmcswain Posted August 12, 2016 Posted August 12, 2016 MillerMG said: I remember using 2007 and if layer zero was frozen you were not able to select the viewport layer if it was on defpoints. The above is correct, except the phrase "viewport layer"? I think you just meant to say "viewport". Already noted this here. Quote
MillerMG Posted August 12, 2016 Posted August 12, 2016 Yes sir. Did not mean to put viewport layer. Just meant viewport. You link was spot on. Looks like I just repeated what was already said. Quote
rkent Posted August 12, 2016 Posted August 12, 2016 David Bethel said: Then that has changed over the years. Pre A2K everything is visible. I did write that a long time ago. -David Just opened 2002 and checked it out, can confirm that the defpoints dots on dimensions continued to show whether the layer was frozen, turned off, or both. Quote
