Hey, I'm trying to export two selection sets of autocad point co-ordinates to two different txt files.
Most of this code was supplied by ASMI
(defun c:pls(/ plSet ptLst plSet)
 (princ"\n<<< Select polyline >>> ")
 (and
  (setq plSet
  (ssget "_:S" '((0 . "LWPOLYLINE"))))
  (setq ptLst
      (mapcar
 '(lambda(x)(trans x 0 1))
(mapcar 'cdr
  (vl-remove-if-not
    '(lambda(x)(= 10(car x)))
      (entget
        (ssname plSet 0))))))
  (sssetfirst nil
    (setq plSet(ssget "_CP" ptLst)))
  (sssetfirst nil
    (setq ss1 (ssget "P"
'((-4 . "<OR")(8 . "PNT0808b")(8 . "PNT0808z")(-4 . "OR>")))
  (sssetfirst nil
    (setq ss2 (ssget "P"
'((8 . "PNT0808b")))
  (if ss1
  (princ
    (strcat "\n"(itoa(sslength ss1))
     " found  ")
    ); end princ
    (princ "\nNothing found  ")
   );end if
  ); end and
 ); end of c:plset
The selection sets I want to export are ss1 and ss2
The problems I have are:
1. How to get the function getfiled to export both selection sets, mabey using it twice? ss1 will be called 1.xyz and ss2 will be called 1.xyb
2. How do I get the selection sets formatted in a usable way. The program I use needs to have the co-ordinates formated like so
4898.260 5011.630 95.500
4898.610 5008.570 95.460
4899.850 5006.170 95.480
4900.530 5003.580 95.530
4900.900 5003.170 95.520
4901.950 4999.660 95.580
I looked at this thread but modifying this code is giving me problems to say the least.
http://www.cadtutor.net/forum/showthread.php?t=9628&highlight=export+point+co-ordinates+txt
Anything you guys can do would help even calling me stupid if the solution is simple :P
Thanks kablam
Update got some of it working!
(defun c:pls(/ plSet ptLst plSet file points c i)
 (and
  (setq plSet
  (setq ptLst
      (mapcar
(mapcar 'cdr
  (vl-remove-if-not
      (entget
  (sssetfirst nil
  ;SEPERATOR
  (sssetfirst nil
    (setq ss1 (ssget "P" '((-4 . "<OR")(8 . "*b")(8 . "*z")(-4 . "OR>")))))
 ;SEPERATOR
_____________________________________|;
;POints to TeXT
 (setq file (open (getfiled "specify output file" "c:/Data08/" "xyz" 1) "w"))
 (setq points (ssget) ss1 0)
 (repeat (sslength points)
   (if (= "POINT" (cdr (assoc 0 (entget (ssname points ss1)))))
     (setq c (cdr (assoc 10 (entget (ssname points ss1))))
    ss1 (1+ ss1)
   (write-line
     (strcat (rtos (car c)) "    "
      (rtos (cadr c)) "    "
      (rtos (caddr c))
     ) file)
 (close file)
   ;SEPERATOR
  (sssetfirst nil
    (setq ss2 (ssget "P" '((8 . "*b")))))
;SEPERATOR
 (setq file1 (open (getfiled "specify output file" "c:/Data08/" "xyb" 1) "w"))
 (setq points1 (ssget) ss2 0)
 (repeat (sslength points1)
   (if (= "POINT" (cdr (assoc 0 (entget (ssname points1 ss2)))))
     (setq c1 (cdr (assoc 10 (entget (ssname points1 ss2))))
    ss2 (1+ ss2)
   (write-line
     (strcat (rtos (car c1)) "    "
      (rtos (cadr c1)) "    "
      (rtos (caddr c1))
     ) file1)
 (close file1)
  (if ss2
  (princ
    (strcat "\n"(itoa(sslength ss2))
     " found  ")
    ); end princ
   );end if
  ); end and
 (Princ)
 ); end of c:plset
