Ydnat Posted February 8, 2010 Posted February 8, 2010 G'day, Can the following lisp (CookieCutter2 v1.2.lsp) be modified to select a polyline by "layername"? or is there script file (not lisp) that can select a closed polyline (or rectangle) by layername and trim/erase all entites outside it? Any help would be appreciated. I run Acad 2008 Cheers CookieCutter2_v1.0.lsp Quote
Lee Mac Posted February 8, 2010 Posted February 8, 2010 Shouldn't that have Joe's Name on it? ;; By Joe Burke ;; Comments and bug reports may be sent to ** email ** ;; What does CC2 do which ExpressTools extrim, AKA CookieCutter, doesn't? ;; Works with blocks, hatches and regions by exploding them. ;; Other object types which cannot be trimmed are left intact. ;; Works with objects which do not use a Continuous linetype. ;; Offers an option to delete all objects on visible layers either ;; inside or outside the selected trim object. Entire thread here: http://www.theswamp.org/index.php?topic=24646.0;all 1 Quote
IsraelS Posted October 2, 2012 Posted October 2, 2012 G'day, Can the following lisp (CookieCutter2 v1.2.lsp) be modified to select a polyline by "layername"? or is there script file (not lisp) that can select a closed polyline (or rectangle) by layername and trim/erase all entites outside it? Any help would be appreciated. I run Acad 2008 Cheers ohh delivers what it promises! Quote
sudheesh Posted November 26, 2013 Posted November 26, 2013 CookieCutter2_v1.0.lsp it cant be trim in 2010 pls hlp me Quote
sudheesh Posted November 26, 2013 Posted November 26, 2013 i try this lisp but its not make any changes. im using cad 2010 can u pls tell me how it ill be work? Quote
sudheesh Posted November 26, 2013 Posted November 26, 2013 yes i tried also EXTRIM but..... i cant trim also irregular polyline over small objects on large area ..... Quote
