G'day,
Can the following lisp (CookieCutter2 v1.2.lsp) be modified to select a polyline by "layername"?
or is there script file (not lisp) that can select a closed polyline (or rectangle) by layername and trim/erase all entites outside it?
Any help would be appreciated.
I run Acad 2008
Cheers :)
CookieCutter2_v1.0.lsp
Shouldn't that have Joe's Name on it?
;; By Joe Burke
;; Comments and bug reports may be sent to ** email **
;; What does CC2 do which ExpressTools extrim, AKA CookieCutter, doesn't?
;; Works with blocks, hatches and regions by exploding them.
;; Other object types which cannot be trimmed are left intact.
;; Works with objects which do not use a Continuous linetype.
;; Offers an option to delete all objects on visible layers either
;; inside or outside the selected trim object.
Entire thread here:
http://www.theswamp.org/index.php?topic=24646.0;all
  • Thanks 1
  • 2 years later...
G'day,
I run Acad 2008
Cheers :)
ohh delivers what it promises!
:D
  • 1 year later...
i try this lisp but its not make any changes. im using cad 2010 can u pls tell me how it ill be work?
yes i tried also EXTRIM but..... i cant trim also irregular polyline over small objects on large area .....
