  • 1 year later...
  • 2 years later...
Thank you for creating this program! I am fairly new to CAD but my father downloaded this LISP many years ago. It was not implemented because some key fittings were missing that are often used in HVAC design. I know this was created a while ago but I thought I would mention it.
Y branch
TY branch
Reducing Y branch
Reducing TY branch
Reducing elbow
If it is possible to implement those components into this program, that would be amazing. If anyone finds another program that has already has all of these components, please let me know. :)
  • 1 year later...
  • 6 months later...
Hi
It gives Dialog file not found in autocad 2016 ..
Hi
Hi,
Are you referring to my program in post# 105?
Hi Tharwat.
HVAC don´t work in Autocad 2014 in spanish.
The error that appears in the command line "Undefined line type"
Regards
Hi Tharwat.
Regards
Hi,
You need to add the LineTypes CENTER and HIDDEN to your acadiso.lin since they are not available in non-English versions as follows:
*CENTER,Center ____ _ ____ _ ____ _ ____ _ ____ _ ____
A, 31.75, -6.35, 6.35, -6.35
*HIDDEN,Hidden __ __ __ __ __ __ __ __ __ __ __ __ __ __
A, 6.35, -3.175
You can find the acadiso.lin as in the following path as an example only:
C:\Users\XXX\AppData\Roaming\Autodesk\AutoCAD 20XX\R20.0\enu\Support\acadiso.lin
Thank you very much.
I have tested the program and it works very well!! Congratulations!!!
I have used (findfile "acadiso.lin") to find acadiso.lin
HVAC program is updated [url="https://autolispprograms.wordpress.com/hvac/hvac
Tharwat Thanks!!
Muchas gracias!!
