Hello everybody,
Is it possible to select inside of a polyline? Thanks!
Have you tried "PSELECT" then type in "WP" or any other options.
My 5 cents
(defun C:ICS (/ en ss lst ssall tmp head)
 ;;InSide Contour Select
 ;;!!!! [b][color="Red"]REQUIRED EXPRESS TOOLS[/color][/b]
 (vl-load-com)
 (if (and (setq en (car (entsel "\nSelect contour: ")))
          (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")
     ) ;_ end of and
     (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3))
     (setq lst (mapcar '(lambda (x) (list (car x) (cadr x))) lst))
     (while lst
       (setq head (car lst)
             tmp  (cons head tmp)
             lst  (vl-remove-if
                    '(lambda (pt) (equal pt head 1e-6))
                    (cdr lst)
                  ) ;_ end of vl-remove-if
       ) ;_ end of setq
     ) ;_ end of while
     (setq lst (reverse tmp)) ;_ end of setq
     (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en)))
     (command "_.Zoom" "0.95x")
     (if (setq ss (ssget "_CP" lst))
       (sssetfirst ss ss)
     ) ;_ end of if
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
(princ "\nType ICS")
Nice lisp, VVA! Can you add option to select or not those objects intersecting the polyline? Those one that are/are not completely inside the poly...?
Other variant (add Outside contour select )
[b][color="Red"];;;!!!! REQUIRED EXPRESS TOOLS[/color][/b]
(defun C:ICS (/ en ss lst  tmp head what)
 (vl-load-com)
         [color="Blue"] (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")[/color]
          (or (initget "CP WP") t)
          (or
          (setq what (getkword "\nChoose option [CrossingPolygon/WindowPolygon] <WP>:"))
          (setq what "WP")
     ) ;_ end of and
     (while lst
             tmp  (cons head tmp)
             lst  (vl-remove-if
                    (cdr lst)
       ) ;_ end of setq
     ) ;_ end of while
     (if (setq ss (ssget (strcat "_" what) lst))
       (sssetfirst ss ss)
     ) ;_ end of if
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
(defun C:OCS (  / en ss lst ssall bbox tmp head)
;;;OutSide Contour Select
(vl-load-com)
 (if (and (setq en (car(entsel "\nSelect contour: ")))
          [color="Blue"](wcmatch (cdr(assoc 0 (entget en))) "*POLYLINE")[/color]
     (setq lst (mapcar '(lambda(x)(list (car x)(cadr x))) lst))
     (while lst
         tmp (cons head tmp)
         lst (vl-remove-if '(lambda(pt)(equal pt head 1e-6))(cdr lst))
     (if (and
           (setq ssall (ssget "_X" (list (assoc 410 (entget en)))))
           (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssall))))
           (setq lst (vl-remove-if '(lambda(x)(minusp
           (cdr(assoc 62 (tblsearch "layer"
           (cdr(assoc 8 (entget x)))))))) lst))
           (setq ssall nil ssall (ACET-LIST-TO-SS lst))
         (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
         (foreach e1 lst (ssdel e1 ssall))
         (SSSETFIRST ssall ssall)
(princ "\nType ICS or OCS")
PS
If you delete or commented out Blue line, then the contour can be also a circle, ellipse, spline
  • 5 years later...
 (vl-load-com)
          (or
          (setq what "WP")
     ) ;_ end of and
     (while lst
             tmp  (cons head tmp)
             lst  (vl-remove-if
                    (cdr lst)
       ) ;_ end of setq
     ) ;_ end of while
       (sssetfirst ss ss)
     ) ;_ end of if
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
(vl-load-com)
     (while lst
         tmp (cons head tmp)
     (if (and
PS
Sorry to resurrect this thread. I have been using this ICS command quite a bit over the last several months. Now all of a sudden it stopped working. Every time I select a polyline, it hangs for a few seconds and then gives the following:
Hard error occurred ***
internal stack limit reached (simulated)
I am using AutoCAD 2007 and have even tried re-installing it to try to correct the issue with no luck. I also tried another computer and it has the same problem.
Any help will be greatly appreciated. This has become one of my favorite commands and now I feel like I lost a finger.
EDIT: So I ran it through VLINE and found which line it was breaking at. It stopped at (list en) in the line below. After commenting it out, it worked.
;; (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en)))
Thanks,
KoKos
Edited by KoKos
  • 2 years later...
This routine is very useful. Would It be possible to add an option to select multiple objects instead of only one, as in Tharwat's routine? The linked routine is missing the OCS option, and interactive CP/WP option, which I appreciate.
