guitarguy1685 Posted January 29, 2010 Share Posted January 29, 2010 do they exist? I'd like to write a lisp to put them in. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 29, 2010 Share Posted January 29, 2010 The settings are stored in a dictionary, you can set them like this: ;;; qlset.lsp - example initialization of QLEADER settings ;;; Frank Whaley, Autodesk ;;; ;;; Two functions are included in this file: ;;; ;;; (acet-ql-Set) ;;; Returns an association list containing the current QLEADER settings from the ;;; Named Object Dictionary. ;;; ;;; (acet-ql-get <alist>) ;;; Sets the specified values for QLEADER settings from the given association ;;; list. ;;; Returns an association list containing the new values. ;;; ;;; These functions can be used to examine the current QLEADER settings, or to ;;; initialize the setting before using the QLEADER command. ;;; For example, to use splined leaders and framed text: ;;; ;;; (acet-ql-set '((65 . 1)(72 . 1))) ;;; ;;; Both functions use the following group codes to identify QLEADER settings: ;;; ;;; 3: user arrowhead block name (default="") ;;; 40: default text width (default=0.0) ;;; 60: annotation type (default=0) ;;; 0=MText ;;; 1=copy object ;;; 2=Tolerance ;;; 3=block ;;; 4=none ;;; 61: annotation reuse (default=0) ;;; 0=none ;;; 1=reuse next ;;; 62: left attachment point (default=1) ;;; 63: right attachment point (default=3) ;;; 0=Top of top line ;;; 1=Middle of top line ;;; 2=Middle of multiline text ;;; 3=Middle of bottom line ;;; 4=Bottom of bottom line ;;; 64: underline bottom line (default=0) ;;; 65: use splined leader line (default=0) ;;; 66: no limit on points (default=0) ;;; 67: maximum number of points (default=3) ;;; 68: prompt for MText width (word wrap) (default=1) ;;; 69: always left justify (default=0) ;;; 70: allowed angle, first segment (default=0) ;;; 71: allowed angle, second segment (default=0) ;;; 0=Any angle ;;; 1=Horizontal ;;; 2=90deg ;;; 3=45deg ;;; 4=30deg ;;; 5=15deg ;;; 72: frame text (default=0) ;;; 170: active tab (default=0) ;;; 0=Annotation ;;; 1=Leader Line & Arrow ;;; 2=Attachment ;;; 340: object ID for annotation reuse ;;; ;;; |; acad-push-dbmod (defun acet-ql-get (/ xr cod itm reply) (if (setq xr (dictsearch (namedobjdict) "AcadDim")) (progn (foreach cod '(3 40 60 61 62 63 64 65 66 67 68 69 70 71 72 170 340) (if (setq itm (assoc cod xr)) (setq reply (append reply (list itm))))) reply) '((3 . "") (40 . 0.0) (60 . 0) (61 . 1) (62 . 1) (63 . 3) (64 . 0) (65 . 0) (66 . 0) (67 . 3) (68 . 1) (69 . 0) (70 . 0) (71 . 0) (72 . 0) (170 . 0)))) (defun acet-ql-set (arg / cur prm) ;; fetch current (setq cur (acet-ql-get)) ;; override per argument (while arg (setq prm (car arg) arg (cdr arg) cur (subst prm (assoc (car prm) cur) cur)) ;; handle DIMLDRBLK (if (= 3 (car prm)) (setvar "DIMLDRBLK" (cdr prm)))) ;; put back (dictremove (namedobjdict) "AcadDim") (setq cur (append '((0 . "XRECORD") (100 . "AcDbXrecord") (90 . 990106)) cur)) (dictadd (namedobjdict) "AcadDim" (entmakex cur)) (acet-ql-get)) ;; load quietly (princ) Or you can entmake the leader and put your overrides in the xData (-3) DXF codes: (entmake (list (cons 0 "LEADER") (cons 100 "AcDbEntity") (cons 100 "AcDbLeader") (cons 71 1) (cons 72 0) (cons 73 3) (cons 74 0) (cons 75 0) (cons 10 pt) (cons 10 pt1) (cons 10 (getpoint pt1 "\nSpecify Next Point")) (list -3 (list "ACAD" (cons 1000 "DSTYLE") (cons 1002 "{") (cons 1070 41) (cons 1040 2.5) (cons 1002 "}"))))) The information for such groups codes can be found here: Art Cooney (artc@autodesk.com) There's a description of the codes in the ObjectARX documentation (I've included it below). I don't think the DXF documentation explains the overrides. Here's the description from the ObjectARX docs: Dimension style overrides can be applied to any of the AcDbEntity types that reference an AcDbDimStyleTableRecord. These are: AcDbAlignedDimension AcDbRotatedDimension AcDbDiametricDimension AcDbRadialDimension AcDb2LineAngularDimension AcDb3PointAngularDimension AcDbOrdinateDimension AcDbLeader AcDbFcf Dimension overrides applied to an object of any of these classes are stored as xdata under the "ACAD" appId in a special subsection. The subsection starts with a group code 1000 (AcDb::kDxfXdAsciiString) with the string "DSTYLE", followed by all the dimension override data bracketed inside a pair of group code 1002's (AcDb::kDxfXdControlString) (the first being a "{" and the other a "}"). Dimension variables in general are called dimvars, and this data is commonly called "per-entity dimvar overrides" or just dimvar overrides. Within the group code 1002 brackets is a chain of dimvar group-code/data-value resbuf pairs, one pair for each dimvar being overridden. The first resbuf in each pair is the DXF group code for the dimvar, as found in the Table below. Since the group code is an integer it has a restype of AcDb::kDxfXdInteger16 (group code 1070). The second resbuf in each pair is the value for that dimvar. Data values for dimvars may be strings, integers, reals, or objectIds. As with resbufs in general, the value of the resbuf’s restype indicates how to read the data in the resval. Please refer to the Table below. As an example, here is a dimension style override list that will override the DIMTAD and DIMGAP variables. The list is shown in AutoLISP format with indenting for clarity. ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 77) (1070 . 1) (1070 . 147) (1000 . 0.2) (1002 . "}") ) In this example the group code 77 is DIMTAD, which is overridden to be 1. Then DIMGAP (group code 147) is set to 0.2. The following code sample uses acutBuildList() to create this resbuf chain and to set overrides for DIMTAD and DIMGAP on the entity pointed to by pEnt, assuming pEnt points to an AcDbEntity of one of the types listed above and is open for writing: resbuf* pRb = acutBuildList( AcDb::kDxfRegAppName, "ACAD", AcDb::kDxfXdAsciiString, "DSTYLE", AcDb::kDxfXdControlString, "{", AcDb::kDxfXdInteger16, 77, AcDb::kDxfXdInteger16, 1, AcDb::kDxfXdInteger16, 147, AcDb::kDxfXdReal, 0.2, AcDb::kDxfXdControlString, "}", RTNONE); Acad::ErrorStatus es = pEnt->setXdata(pRb); acutRelRb(pRb); It is very important the xdata you set onto an object have the proper sequence of resbufs. Each override must have both the DXF group code resbuf and the associated value resbuf. In addition, the value must be the correct data type (string, real, or int) and must be within the allowable range for that dimvar. If any of these conditions are not met, AutoCAD may terminate. Also, the 1000 "DSTYLE" and the following 1002 "{" "}" set must be present, and there must only be one set of all of these. Remember that xdata is obtained and replaced on a per-appId basis. To modify any dimension overrides, work with the complete list of xdata for the "ACAD" appId, which may have other data, including other dimension overrides. So, be sure to obtain whatever xdata may already be present for the "ACAD" appId (use the object's xData() method with the string "ACAD"). Add or remove only the dimension override information you need, making sure that if dimension override information already exists you don't duplicate any of the xdata that's already there (including the "DSTYLE" string and the 1002 "{" "}" bracket pairs). Place new overrides in between the existing 1002 bracket pair, and put the complete modified list back into the object via the object's setXData() method. If not done correctly, AutoCAD may terminate. Here is a table of all the DimStyleTableRecord dimvars, with their DXF group codes, data types, and value ranges: Group code Dimension variable Data type Value range 3 DIMPOST string any 4 DIMAPOST string any 40 DIMSCALE real >= 0.0 41 DIMASZ real >= 0.0 42 DIMEXO real >= 0.0 43 DIMDLI real >= 0.0 44 DIMEXE real >= 0.0 45 DIMRND real >= 0.0 46 DIMDLE real >= 0.0 47 DIMTP real >= 0.0 48 DIMTM real >= 0.0 71 DIMTOL int 0 = off, 1 = on 72 DIMLIM int 0 = off, 1 = on 73 DIMTIH int 0 = off, 1 = on 74 DIMTOH int 0 = off, 1 = on 75 DIMSE1 int 0 = off, 1 = on 76 DIMSE2 int 0 = off, 1 = on 77 DIMTAD int 0 - 3 78 DIMZIN int 0 - 15 79 DIMAZIN int 0 - 15 new 140 DIMTXT real >= 0.0 141 DIMCEN real any value 142 DIMTSZ real >= 0.0 143 DIMALTF real >= 0.0 144 DIMLFAC real >= 0.0 145 DIMTVP real >= 0.0 146 DIMTFAC real >= 0.0 147 DIMGAP real any value 148 DIMALTRND real >= 0.0 new 170 DIMALT int 0 = off, 1 = on 171 DIMALTD int >= 0 172 DIMTOFL int 0 = off, 1 = on 173 DIMSAH int 0 = off, 1 = on 174 DIMTIX int 0 = off, 1 = on 175 DIMSOXD int 0 = off, 1 = on 176 DIMCLRD int 0 - 256 177 DIMCLRE int 0 - 256 178 DIMCLRT int 0 - 256 179 DIMADEC int 0 - 8 new 271 DIMDEC int 0 - 8 272 DIMTDEC int 0 - 8 273 DIMALTU int 1 - 8 274 DIMALTTD int 0 - 8 275 DIMAUNIT int 0 - 4 276 DIMFRAC int 0 - 2 new 277 DIMLUNIT int 0 - 4 new 278 DIMDSEP int (char) any char new 279 DIMATMOVE int 0 - 2 new 280 DIMJUST int 0 - 4 281 DIMSD1 int 0 = off, 1 = on 282 DIMSD2 int 0 = off, 1 = on 283 DIMTOLJ int 0 - 2 284 DIMTZIN int 0 - 15 285 DIMALTZ int 0 - 15 286 DIMALTTZ int 0 - 15 288 DIMUPT int 0 = off, 1 = on 289 DIMATFIT int 0 - 3 new 340 DIMTXSTY objectId new 341 DIMLDRBLK objectId new 342 DIMBLK objectId new 343 DIMBLK1 objectId new 344 DIMBLK2 objectId new 371 DIMLWD int lineweights new 372 DIMLWE int lineweights new Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted January 29, 2010 Author Share Posted January 29, 2010 very interesting thanks so much Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 29, 2010 Share Posted January 29, 2010 You're welcome Quote Link to comment Share on other sites More sharing options...
