MiGo Posted January 29, 2010 Share Posted January 29, 2010 I need help. I am working on a project in REVIT 2010 and this program doesn't recognize linetypes with letters in them. So when I import an AutoCAD drawing they are all solid lines. What I am looking for is a lisp (for AutoCAD) that will recognize the selected lines linetype and create a small line then a piece of text and repeat this for the length of the line. If anyone knows if this is even possible please let me know. For now I have just been doing this manually and it is very very time consuming. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 29, 2010 Share Posted January 29, 2010 Perhaps this might interest you. I altered ExpressTools Text Explode to explode lines (lnexp.lsp). As you can see in the picture by the grips, the bottom line is a line, and the top line is exploded into separate lines. The text is no longer text, but polylines. ;; ;;; ;;; By Dominic Panholzer ;;; ;;; TXTEXP.LSP ;;; Copyright © 1999 by Autodesk, Inc. ;;; ;;; Your use of this software is governed by the terms and conditions of the ;;; License Agreement you accepted prior to installation of this software. ;;; Please note that pursuant to the License Agreement for this software, ;;; "[c]opying of this computer program or its documentation except as ;;; permitted by this License is copyright infringement under the laws of ;;; your country. If you copy this computer program without permission of ;;; Autodesk, you are violating the law." ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;; ---------------------------------------------------------------- ;;; ;;; External Functions: ;;; ;;; ACET-ERROR-INIT --> ACETUTIL.FAS Intializes bonus error routine ;;; ACET-ERROR-RESTORE --> ACETUTIL.FAS Restores old error routine ;;; ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS Zoom boundry to include points given ;;; ACET-LAYER-LOCKED --> ACETUTIL.FAS Checks to see if layer is locked ;;; ACET-GEOM-PIXEL-UNIT --> ACETUTIL.FAS Size of pixel in drawing units ;;; ACET-GEOM-TEXTBOX --> ACETUTIL.FAS Returns the textbox for any text ;;; ACET-GEOM-MIDPOINT --> ACETUTIL.FAS Returns midpoint between two points ;;; ACET-GEOM-VIEW-POINTS --> ACETUTIL.FAS Returns corner points of screen or viewport ;;; ACET-STR-FORMAT --> ACETUTIL.ARX String builder ;;; ACET-WMFIN --> ACETUTIL.FAS Brings in WMF file ;;; ; Amended by eldon to explode a line January 2009 (defun c:lnexp (/ grplst getgname blknm FLTR GLST GDICT SS VIEW UPLFT TMPFIL TBX TMPFIL CNT PT1 PT2 ENT TXT TXTYP PTLST ZM LOCKED GNAM vpna vplocked) (acet-error-init (list (list "cmdecho" 0 "highlight" 1 "osmode" 0 "Mirrtext" 1 "limcheck" 0 ) T ) ) ; --------------------- GROUP LIST FUNCTION ---------------------- ; This function will return a list of all the group names in the ; drawing and their entity names in the form: ; ((<ename1> . <name1>) ... (<enamex> . <namex>)) ; ---------------------------------------------------------------- (defun acet-txtexp-grplst (/ GRP ITM NAM ENT GLST) (setq GRP (dictsearch (namedobjdict) "ACAD_GROUP")) (while (setq ITM (car GRP)) ; While edata item is available (if (= (car ITM) 3) ; if the item is a group name (setq NAM (cdr ITM) ; get the name GRP (cdr GRP) ; shorten the edata ITM (car GRP) ; get the next item ENT (cdr ITM) ; which is the ename GRP (cdr GRP) ; shorten the edata GLST ; store the ename and name (if GLST (append GLST (list (cons ENT NAM))) (list (cons ENT NAM)) ) ) (setq GRP (cdr GRP)) ; else shorten the edata ) ) GLST ; return the list ) ; ------------------- GET GROUP NAME FUNCTION -------------------- ; This function returns a list of all the group names in GLST ; where ENT is a member. The list has the same form as GLST ; ---------------------------------------------------------------- (defun acet-txtexp-getgname (ENT GLST / GRP GDATA NAM NLST) (if (and GLST (listp GLST)) (progn (foreach GRP GLST (setq GDATA (entget (car GRP))) (foreach ITM GDATA ; step through the edata (if (and (= (car ITM) 340) ; if the item is a entity name (eq (setq NAM (cdr ITM)) ENT) ; and the ename being looked for ) (setq NLST ; store the ename and name (if NLST (append NLST (list (cons (car GRP) (cdr GRP)))) (list (cons (car GRP) (cdr GRP))) ) ) ) ) ) ) ) NLST ) ; ---------------------------------------------------------------- ; MAIN PROGRAM ; ---------------------------------------------------------------- (if (and ; Are we in plan view? (equal (car (getvar "viewdir")) 0 0.00001) (equal (cadr (getvar "viewdir")) 0 0.00001) (> (caddr (getvar "viewdir")) 0) ) (progn (prompt "\nSelect line to be EXPLODED: ") (Setq FLTR '((-4 . "<AND") ;(-4 . "<OR") ; filter for mtext and text ; (0 . "MTEXT") ; (0 . "TEXT") ;(-4 . "OR>") (-4 . "<NOT") (102 . "{ACAD_REACTORS") ; and not leader text (-4 . "NOT>") (-4 . "AND>") ) GLST (acet-txtexp-grplst) ; Get all the groups in drawing GDICT (if GLST (dictsearch (namedobjdict) "ACAD_GROUP") ) SS (ssget FLTR) CNT 0 ) ;; filter out the locked layers (if SS (setq SS (car (bns_ss_mod SS 1 T))) ) ;if ;; if we have anything left (if SS (progn (setq CNT 0) ; Reset counter (while (setq ENT (ssname SS CNT)) ; step through each object in set (and GLST ; if groups are present in the drawing (setq GNAM (acet-txtexp-getgname ENT GLST)) ; and the text item is in one or more (foreach GRP GNAM ; step through those groups (command "_.-group" "_r" ; and remove the text item (cdr GRP) ENT "" ) ) ) (setq TBX (acet-geom-textbox (entget ENT) 0)) ; get textbox points (setq TBX (mapcar '(lambda (x) (trans x 1 0) ; convert the points to WCS ) TBX ) ) (setq PTLST (append PTLST TBX)) ; Build list of bounding box ; points for text items selected (setq CNT (1+ CNT)) ; get the next text item ); while (setq PTLST (mapcar '(lambda (x) (trans x 0 1) ; convert all the points ) ; to the current ucs PTLST ) ) (if (setq ZM (acet-geom-zoom-for-select PTLST)) ; If current view does not contain (progn ; all bounding box points (setq ZM (list (list (- (caar ZM) (acet-geom-pixel-unit)) ; increase zoom area by (- (cadar ZM) (acet-geom-pixel-unit)) ; one pixel width to (caddar ZM) ; sure nothing will be lost ) (list (+ (caadr ZM) (acet-geom-pixel-unit)) (+ (cadadr ZM) (acet-geom-pixel-unit)) (caddr (cadr zm)) ) ) ) (if (setq vpna (acet-currentviewport-ename)) (setq vplocked (acet-viewport-lock-set vpna nil)) );if (command "_.zoom" "_w" (car ZM) (cadr ZM)) ; zoom to include text objects ) ) (setq VIEW (acet-geom-view-points) TMPFIL (strcat (getvar "tempprefix") "txtexp.wmf") PT1 (acet-geom-midpoint (car view) (cadr view)) PT2 (list (car PT1) (cadadr VIEW)) ) (if (acet-layer-locked (getvar "clayer")) ; if current layer is locked (progn (command "_.layer" "_unl" (getvar "clayer") "") ; unlock it (setq LOCKED T) ) ) (command "_.mirror" SS "" PT1 PT2 "_y" "_.WMFOUT" TMPFIL SS "") (if (findfile tmpfil) ; Does WMF file exist? (progn (command "_.ERASE" SS "") ; erase the orignal text (setq ss (acet-wmfin TMPFIL)) ; insert the WMF file (command "_.mirror" ss "" PT1 PT2 "_y") ) ;progn ) ;if (if LOCKED (command "_.layer" "_lock" (getvar "clayer") "") ; relock if needed ) ;if (if ZM (command "_.zoom" "_p")) ; Restore original view if needed (if vplocked (acet-viewport-lock-set vpna T) ;re-lock the viewport if needed. );if (prompt (acet-str-format "\n%1 text object(s) have been exploded to lines." CNT)) (prompt "\nThe line objects have been placed on layer 0.") ) ) ) (prompt "\nView needs to be in plan (0 0 1).") );if equal (acet-error-restore) ; Retsore values (princ) ) (princ) Quote Link to comment Share on other sites More sharing options...
MiGo Posted January 29, 2010 Author Share Posted January 29, 2010 Can I alter the name of the defun as to not override the Express tool lisp? I just don't want to get into any issues with work boundaries. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 29, 2010 Share Posted January 29, 2010 If you scroll down to where I have added the comment about changing it, I have called the function "lnexp" (line explode), so that it does not overwrite the original txtexp. Quote Link to comment Share on other sites More sharing options...
MiGo Posted January 29, 2010 Author Share Posted January 29, 2010 NVM I notice you have changed it to be lnexp. I'll give it a try thanks. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 29, 2010 Share Posted January 29, 2010 One slight word of warning, I have found with long lines, the scaling is not perfect, so be prepare to tweak each end line to give the same overall dimension. Quote Link to comment Share on other sites More sharing options...
MiGo Posted January 29, 2010 Author Share Posted January 29, 2010 It seems to remove the line from it's original location and they letters are showing up mirrored across the X and Y axis somewhere other than 0,0. Quote Link to comment Share on other sites More sharing options...
MiGo Posted January 29, 2010 Author Share Posted January 29, 2010 The drawings that I am working in are site plans so the units was set to feet. When I changed it to inches the lines now show up back where they started but the letters are still reversed. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 29, 2010 Share Posted January 29, 2010 It does not seem perfect, and I did have to mirror the text about the line. It also changes everything to layer 0, gives it a Lineweight of zero, to name but a few, BUT it does explode the line. It works by exporting a WMF image out of the drawing, amd then re-importing the image. Perhaps you have to do too much editting for it to be of use. Quote Link to comment Share on other sites More sharing options...
