I have this lisp I used for basic ask and do commands:
 (defun c:SETUP ()
  (initget "122X34 224X36 330X42")
  (setq SIZE (getkword "\nEnter name [1]22X34,[2]24X36,[3]30X42: "))
(cond
     ((= SIZE "122X34")
        (initget "1FULL 21/2=1")
        (setq SCALE (getkword "\nEnter state [1]FULL,[2]1/2=1:"))
        (cond
           ((= SCALE "1FULL")
              (command "MIRRTEXT" "0"))
    ((= SCALE "21/2=1")
              (command "MIRRTEXT" "1"))
     ((= SIZE "224X36")
        (cond
           ((= SCALE "1FULL")
          ((= SCALE "21/2=1")
     ((= SIZE "330X42")
        (cond
           ((= SCALE "1FULL")
              (command "MIRRTEXT" "O"))
          ((= SCALE "21/2=1")
Everything works fine I just want to add multiple line of command for each SCALE. What would I have to do to the lisp, for each line of extra commands. See below for what I mean! It will have this next to it(;;
((= SIZE "122X34")
        (cond
           ((= SCALE "1FULL")
              (command "DIMSCALE" "48");;<==THIS IS WHAT I WANT TO ADD
              (command "LTSCALE" "24");;<==THIS IS WHAT I WANT TO ADD
    ((= SCALE "21/2=1")
              (command "DIMSCALE" "96");;<==THIS IS WHAT I WANT TO ADD
              (command "LTSCALE" "48");;<==THIS IS WHAT I WANT TO ADD
I want to add something like that to each size under each scale option.
Thanks for everything in advance!!!
((= SIZE "122X34")
        (cond
           ((= SCALE "1FULL")
              (command "DIMSCALE" "48"));;<==THIS IS WHAT I WANT TO ADD
              (command "LTSCALE" "24"));;<==THIS IS WHAT I WANT TO ADD
    ((= SCALE "21/2=1")
              (command "DIMSCALE" "96"));;<==THIS IS WHAT I WANT TO ADD
              (command "LTSCALE" "48"));;<==THIS IS WHAT I WANT TO ADD
quote]
Why is it if I only put two command lines they both work, but if I add a third like above only the first and third ones work?
Hey neekcotrack
The code is fine, it is just a case of balancing the brackets
(cond
((= SCALE "1FULL")
Try keep all expresions to be evaluated for a particular condition in the same list
eg. (cond
((if true)(exp1)(exp2)(exp...));first expression
((if true)(exp...)) ;second expression
);end of cond
((= SIZE "122X34")
 (cond
   ((= SCALE "1FULL")
    );end of first test
   ((= SCALE "21/2=1")
    );end of second test
Regards
jammie
