Smiler Posted January 28, 2010 Posted January 28, 2010 Hi everyone, This is my first post and i hope someone can give me some pointers. I've used Acad since 1990 in the engineering & construction industrys but unfortunatley through job moves etc i have only ever used 2D. I'm obviously being left behind skills wise and my current company is not interested in increasing their cad skills base 3D wise, although it would be beneficial to them. So with this in mind can anyone recommend a course or tutorial that takes me from 2D to 3D and will allow me to study and work through in my own time? Thanks in advance Quote
ReMark Posted January 28, 2010 Posted January 28, 2010 Check out the CAD Institute offered through Murray State College. The courses cost about the same as one would at your local community college and come with the added benefit of free software (imagine using AutoCAD 2010 instead of 2002!). The courses are offered online and they are self-paced. Students receive a workbook and must complete assignments which are then emailed to the professor. Here is a link to get you started: http://www.cadinstitute.com/ By the way, I took the AutoCAD in 3D course. Quote
Pablo Ferral Posted January 28, 2010 Posted January 28, 2010 I recommend the tutorials on 'My Cad Site' as a good introduction to 3D Autocad. http://www.we-r-here.com/cad/tutorials/level_3/3-1.htm However, if you work in engineering and construction you may want to look at Revit or Inventor... Quote
ReMark Posted January 28, 2010 Posted January 28, 2010 You should also check out the tutorials here at CADTutor. Look at the very top of this page in the upper left-hand corner. Quote
Smiler Posted January 28, 2010 Author Posted January 28, 2010 Thanks for the replys...Great Help Quote
ReMark Posted January 28, 2010 Posted January 28, 2010 Another option available to newbie AutoCAD users: http://www.autocadmark.com/mambo/content/view/67/83/ Quote
bmctest Posted January 28, 2010 Posted January 28, 2010 @smiler As someone already touched on a bit, you should check into what 3D program seems to be the industry standard for your industry. For example, you wouldn't want to spend all your time learning 3D AutoCAD, if your industry is using Revit or some other program. Quote
Tankman Posted January 28, 2010 Posted January 28, 2010 Here's two links for you. Tutorials, keep in mind you can save the *.pdf files to your PC. Enjoy! http://www.andrew.cmu.edu/course/48-568/2DVideosWEB_files/frame.htm http://www.andrew.cmu.edu/course/48-568/PDFs/3D_AutoCAD_2009.pdf Quote
