SLW210 Posted June 29, 2011 Share Posted June 29, 2011 Hi guys,.. I've just read this thread...by searching some explaination about vl-load-com. I know this is not make sence,....but it is true, By installing TrueView, this will solve most of CAD problem. eaven repair option do not do the trick. So i'm a little confused about the files shared between AutoCAd and TrueView. Also, i've noted that if you do not install TrueView, you can not open DWG in DesignReview so now this is another undocumented Thing.. With all respect, I'Ve never received any support from AutoDESK eaven with over 300 AutoDESK network licence owner, I found more support and skilled user in some CAD forum like this one. cheers ! Andrea. I used DesignReview several times previous to my installation of DWG TrueView. Are you using AutoCAD 2008? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted June 29, 2011 Share Posted June 29, 2011 (edited) I just stumbled upon this thread... Yes I tried typing (vl-load-com) in the command line then restarting the vlide ....but that does not work. ... God knows why its looking for the ACAD2009DOC.lsp when I have never used acad 2009 on this machine!!??? ... I have just found out that every other user in our office has the same problem:( The problem has been fixed - so just for the record and if anyone else has the same problem: Install "Trueview" and "Design review" what conculsion? the only point I was trying to make was that installing TV and DR fixes the problem. ... True - but I know you can not explain why installing True view and design review fixes the problem. Unless you have something to do with designing Autocad software I doubt if anyone will find the reason. I really would have liked to have sees the return for (findfile "acad2009doc.lsp") before this issue was fixed (by TV & DR!? LoL), because my initial thought was that the OP was experiencing a profile issue with their new deployment... [stewieGriffinVoice] Perhaps there was a missing Support File Search Path? Huh? Maybe a little CAD Manager whoopsie!? Ehh? A little bit of the "New Platform" jitters!?? [/stewieGriffinVoice] Who knows, perhaps an extra code snippet made it's way into acad.lsp that corrected the little snag that the OP's entire office was experiencing. ... I'm just saying. It could've happened. LoL Edited June 29, 2011 by BlackBox Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 29, 2011 Share Posted June 29, 2011 [stewieGriffinVoice]Perhaps there was a missing Support File Search Path? Huh? Maybe a little CAD Manager whoopsie!? Ehh? A little bit of the "New Platform" jitters!?? [/stewieGriffinVoice] Another Family Guy fan! Quote Link to comment Share on other sites More sharing options...
