stew Posted August 13, 2008 Posted August 13, 2008 I work in the metric world, How do I set the decimal point for area, height, etc., in the properties dialog box ?? I work in millimeters, but would like to read area in m2 in the properties box or the list window. Is this possible ?? Quote
stew Posted August 14, 2008 Author Posted August 14, 2008 I work in millimeters, but would like to read area in m2 in the properties box or the list window. Is this possible ?? Quote
dbroada Posted August 14, 2008 Posted August 14, 2008 basically, no. AutoCAD works in units, you tell it what those units are. It is possible to put a multiplier in your dim style so you can have mm dimensions displayed in meters but I don't know how to change anything in properties. Quote
stew Posted August 15, 2008 Author Posted August 15, 2008 thanks for your attention, we can only live in hope that ""all we want"" will be programable somehow someday, cheers from NZ Quote
fuccaro Posted August 15, 2008 Posted August 15, 2008 From the Properties panel you can access the quick calculator. Here you can define your own function to multiply the shown number with 10e9 (or with whatever value you wish). Or use the built-in units converter. The data will still show in default units, but you can get the desired results with just a few clicks. However I don't think it worts for just a simple calculus -you can just mentally move the decimal point. Well, just my thoughts. Quote
