criscris27 Posted August 13, 2008 Posted August 13, 2008 Hy! I am a beginner in Autocad, so i am following the steps as the tutorials say, but still i couldn't manage to draw a rectangle: i used the polyline and the 'c' disappeared when i pressed 'enter' . Why is that happening? C Quote
lpseifert Posted August 13, 2008 Posted August 13, 2008 If I understand what you're asking... Enter exits the command; if you want to 'Close' the polyline hit 'C' then Enter... or use the rectangle command Quote
criscris27 Posted August 13, 2008 Author Posted August 13, 2008 i type 'c' and then i press 'enter', but soon after i press enter the 'c' disappears and the rectangle isn't closed Quote
lpseifert Posted August 13, 2008 Posted August 13, 2008 How about a screen shot of what you've drawn prior to hitting 'C' 'Enter'? Quote
criscris27 Posted August 13, 2008 Author Posted August 13, 2008 by a 'screen shot' you mean print screen?? i tryed that(print screen) and i couldn't upload because the file size exceeded the maximum limit Quote
rkent Posted August 13, 2008 Posted August 13, 2008 on the last line of the command where it shows *cancel*, there should be a C there. When you get to that point you should type the letter C and hit enter or space bar. Or right click and pick close there. Quote
criscris27 Posted August 14, 2008 Author Posted August 14, 2008 thanks, now i understood..... i'll be back ...for sure Quote
