Deleting extra Viewport Scales?
Here is a screen shot of my C3D.
Can you tell me how to get rid of all the viewport scales? like where did 1:1_XREf_11_14_XREF_XREF_XREF Come from?
Are you current with updates/service packs?
yeah just had a clean reinstall. It is 2008 however.
no I havent. I'll let you know. Thanks
Just tried and got this:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at Autodesk.AutoCAD.ApplicationServices.ScaleListHelpers.loadScaleList(String[] scaleStr, Double[] scaleNum, Double[] scaleDenom, Int32[] scaleCount)
at Autodesk.AutoCAD.ScaleList.ScaleListForm.Read()
at Autodesk.AutoCAD.ScaleList.ScaleListForm.restoreData(Boolean bResetIfNoData)
at Autodesk.AutoCAD.ScaleList.ScaleListForm..ctor()
at Autodesk.AutoCAD.ScaleList.Commands.ScaleListEditCmd()
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgCommandClass.InvokeWorkerWithExceptionFilter(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgCommandClass.Invoke(AcMgCommandClass* , gcroot<:reflection::methodinfo>* mi, Boolean bLispFunction)
at AcMgCommandClass.CommandThunk.Invoke(CommandThunk* )
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.1.0.0
Win32 Version: 17.1.219.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.4053
Win32 Version: 8.00.50727.4053
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989/msvcm80.dll
acmgd
Win32 Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/acmgd.DLL
ResourceManagement
Assembly Version: 11.0.79.0
Win32 Version: 11.0.079.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/ResourceManagement.DLL
Redland.NET
Assembly Version: 1.0.2.1
Win32 Version: 1.0.2.1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/Redland.NET.DLL
AcInfoCenterConn
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AdInfoCenter.DLL
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Interop.AcInetEngine
Assembly Version: 17.1.51.0
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/en-US/AdInfoCenter.resources.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
1ofhrlux
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcLayer.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcMgdShared.DLL
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/acmgdinternal.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/en-US/AcLayer.resources.DLL
Autodesk.Interop.WSCommCntr1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/Autodesk.Interop.WSCommCntr1.DLL
Autodesk.Interop.WebServices1
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/Autodesk.Interop.WebServices1.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
giypl3ur
AcLayerTools
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcLayerTools.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/en-US/AcLayerTools.resources.DLL
AcScaleList
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/AcScaleList.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202008/en-US/AcScaleList.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT de****** registered on the computer
rather than be handled by this dialog box.
try using -SCALELISTEDIT
then use the option RESET
