Hi guys,
When i use the layoff button on the toolbar (Light bulb off) i receive the message "Current settings: Viewports=Vpfreeze, Block nesting level=Block" i have only notice this today and so was wondering if a) its always been there b) What it is and does it effect anything c)how do i change it.
Thanks
L.
I believe you are referring to the "Layer Off" button on the Layer Manager toolbar, aren't you?
The messages you refer to. Where are you seeing them? On the command line or in some sort of dialog box or pop-up window?
um, yes i think so, its on a toolbar called layers II on our system but that might be due to personal configuration, the button just represents the command _layoff and allows you to pick an object on a layer and turn that layer off, the resuting text appears on the command line, it does also appear if i simply type in _layoff also.
L.
Then I would suggest that it is "normal" and not to worry about it.
a) I see it as well when I start the command so at least it's not just you
b) no idea
c) by typing Settings (or just S) instead of selecting an object's layer to turn off.
